Register FAQ Social Groups
Old 11-23-2009, 04:00 PM
HeWhoKillz HeWhoKillz is offline
air compressor
I was taking the air compressor off my car because it hasn't worked for years and wanted to take it apart. I went to unbolt one of the two bolts that holds the metal lines that goes into the firewall and it hissed as if there was air inside. Whats going on with that? I thought those lines had fluid in them not air.
Old 11-23-2009, 05:14 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: air compressor
AC systems have either R12 or 134A refrigerant in them depending on the year of the car. On a working AC system, the refrigerant is either in a liquid or vapor state depending on where in the cycle it is. If the compressor has not worked in years, the system could still have a charge of refrigerant left.
You should have had the system drained by a shop that can recover the refrigerant before you removed the compressor.
Oh well, so much for our ozone layer
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 11-23-2009, 10:46 PM
Re: air compressor
Actually I stopped before it leaked out too much lol. So there is still plenty inside. Whats the difference between me leaving them bolts undone and letting the vapors out and a shop doing it?
Old 11-24-2009, 11:06 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: air compressor
The refrigerant in the lines never wears out or goes bad. This means an AC mechanic can evacuate (suck out) the refrigerant and recycle it so it can be used in another car.
If you simply let the gas escape, it will drift around in the atmosphere a LONG time. Often, some of this gas makes its way into Earth's upper atmosphere and starts to destroy the ozone (O3) layer, allowing more of the sun's ultraviolet radiation to make its way to the surface. This can negatively affect plant and animal life.
FWIW, the ozone layer is in a constant state of destruction and creation..... but the introduction of refrigerant upsets this equilibrium. R134A is less harmful than the R12, but it still has an effect.
http://en.wikipedia.org/wiki/Ozone_depletion
Old 11-24-2009, 09:16 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: air compressor
Think of the refrigerant in your system like the butane in a lighter or propane in a tank. Its liquid inside under high pressure. As soon as it hits atmospheric pressure it violently evaporates. That violent evaporation is what makes your A/C system work.
Have it evacuated by a shop, then do your work. That evaporating liquid is extremely cold. It can cause violent things to happen, and can give you frostbite in a matter of seconds. Don't underestimate how careful you have to be with it.
Dragging people kicking and screaming into the enlightenment.
Old 11-26-2009, 04:38 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: air compressor
Uh not to mention that if released in an enclosed space, you could breathe it in...not good for brain cells.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 12-01-2009, 04:32 PM
MagicRat's Avatar
Re: air compressor
The popular refrigerants (R12, R134A) are completely non-reactive, that is, you can breathe them in with no harm done at all. It is non-posionous.
It can suffocate you if you breathed in 100% of the stuff, but there is not enough refrigerant in the car to do that. You could also freeze your lungs if you tried to deliberatly suck it up straight from the pipe. But accidentally breathing it in will do no harm.
The risk comes from the possible presence of other refrigerants. It was possible to get propane-based refrigerants, which are explosive and harmful. These were not widely used, but you can never be sure what's in there
