Register FAQ Social Groups
Old 02-16-2003, 09:36 PM
5_LiTeR_EaTeR 5_LiTeR_EaTeR is offline
Send a message via AIM to 5_LiTeR_EaTeR
Overheating Problems b16a CRX
So far I have replaced Headgasket and waterpump while I was in there, Themostat, radiator, Coolant lines & Coolant temp sensor. It doesn't over heat right away.The needle will stick around middle of the gauge for a bit then just go up to hot. It will blow the coolant right out of the overflow bottle and then I have to refill it. when I do it takes about half a gallon. When the gauges reads hott it does't flicker at the top. When its really* over heating like when theres a bad coolant leak the gauge will go up and down sorta like a tach when you hit the rev limiter. I did a block check so I know its not a head gasket. The gauge just reads hott. For it to overheat it has to be mechanical so I am guessing maybe an impeller broke off the water pump. I replaced the coolant temp sensor twice. I get some heat thats not too hot but after a hard run it blows out freggin cold. I don't think its electrical. I am guessing maybe a coolant temp switch? I am thinking of replacing the water pump again. I know that the themostat isn't in backwards. I see it as a hard on going into the block. I know the shaft looking side with the spring goes towards the block but i am not sure on a honda. My idle goes up really high like to 3k but thats just prob the coolant temp sensor reading open loop again cuz it doesn;'t read coolant cuz it blew out and has a air pocket in it, therfore it will kick the idle up cuz it thinkgs the engine is cold. I dunno I thought I'd give it a shot here cuz I can't igure out wtf it is. My climate control panel is smashed in typical for a crx. I got all my parts for a 90 integra. Could it be possible to use a thermostat from a delsol? I dunno what else to do any input from you guys is greatly appreciated. Thanks!
~Alex~
VTEC WORKING FINALLY & HAULIN SOME ASS!!
If the shadow of your car is smokin' you it definately means you are smokin' someone else!!
KKK k24 Turbo on the way to the install!
Overheating Problem 95 Geo Metro Too Many Old Cars Metro 6 08-13-2010 05:11 AM
my 1997 dodge neon keeps overheating Lavette General Discussion 2 08-23-2009 07:15 PM
b16a crx si vs b18a crx si part 2! civicHBsi91 Street/Track Racing Stories! 5 05-04-2004 12:30 AM
b16a problem on crx, engine problem crxsirpr Let's get Technical! 0 03-02-2004 03:25 PM
Overheating Problems b16a CRX 5_LiTeR_EaTeR Engineering/ Technical 4 07-15-2003 02:35 PM
