Go Back   Automotive Forums Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 01-17-2003, 12:36 PM
CivicSkater CivicSkater is offline
Banned
Querstion About Coil overs
On my 90 accord lx, what is the most i could lower my car with 17" wheels, and still be able to go over the curb of my driveway, and speed bumps, without bottoming out?
Old 01-17-2003, 12:38 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
depends how big the curbs an speed bumps are . nah, but i'd say u could lower around 2 inches an be fine. i had 17's on my accord w/ the H&R Racing drop which is around 2.25 in the front an a lil lower in the rear (i think). my drop was over 2 inches an was fine. jus gotta take it slow an be careful as with any drop. good luck.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 01-18-2003, 04:29 PM
accord92 accord92 is offline
mine is dropped around 2.75 and the only thing i ever scrape is my mud flaps...like krnx said...you just have to take it slow and be careful.
Old 01-19-2003, 07:35 PM
Banned
thanks a lot
Old 01-23-2003, 05:08 AM
-=Evol90Accord=- -=Evol90Accord=- is offline
eww, you still have your mudflaps on? that was actually my first mod... taking the damn things off!
its a lowered family sedan... how fast could it possibly go??
Old 01-23-2003, 03:35 PM
sickhonda's Avatar
sickhonda sickhonda is offline
You might be able to take it SLOW on side roads, but not on highway driving...risky and dangerous thing to do. Not all higways are in perfect smooth condition, unexpected bumps are everywhere. Its your ride, however low you decide to go with the 17" rims, just remember you need the camber kit after 1.50-1.75", and make sure you select the correct offset for the rims so that your tires will be tucked in. Another thing you need to know, 17" will make your ride look sharp but slow. Good luck!
Old 01-23-2003, 03:41 PM
Banned
Wait, a minute, im thinkin about not gettin 17's and just keeping the stock rims and getting new hubcaps, so i will be lowering it more. Whats a camber kit, and how do i select the right offset for the rims?
Old 01-23-2003, 03:55 PM
sickhonda's Avatar
If you're keeping the stock rims then you don't need to worry about offset. The camber kit is to give your car the adjustability needed to correct the toe-in/toe-out alignment for your tires...meaning, giving all tires even contact to the ground. Not in an angle, which normally occurs after lowering the vehicle.
Old 01-23-2003, 04:01 PM
Accord_Racer03 Accord_Racer03 is offline
Send a message via AIM to Accord_Racer03 Send a message via Yahoo to Accord_Racer03
I have Eibach Sportline springs and tokicos and I'm sitting pretty low. I'd guess I'm 2.5 - 3.0 lower than stock. It's low enough that the bottom lip of the front bumper will just barely go over a normal size curb. It scrapes but it goes over. I just have the stock 15" wheels right now. I'm just trying to give you something to compare with. If I were you I'd get 16 wheels and lower it about 2.5 inches. You should be good to go. Also, a camber kit is something that you attach to your control arms to adjust the tilt in your wheels. When you lower your car the wheels will point inward (negative camber). On the other hand if you jack up your truck like crazy you get caster (positive camber). So a camber kit just corrects the problem and straightens up your wheels. There is how-to's everywhere about how to check your camber.
http://www.automotiveforums.com/vbulletin/t16284.html
Here's a trick for rear camber:
http://www.automotiveforums.com/vbulletin/t25575.html
Old 01-23-2003, 07:32 PM
Banned
Well, the reason im keepin the stock rims is cuz im in high school, and i have like no money, so im basically goin with everything as low budget as i can, without makin it look like crap. Thanks a lot for the explanation, i actually know what you mean now. How much would a camber kit be, and is it easy to install, or would i have to get somebody to do it for me?
Old 01-23-2003, 07:34 PM
Banned
AccordRacer, do you have any pictures of your ride, i wanna see what it looks like with just the stock wheels. If you do, just send em to me at [email protected]
o ya, make the heading something crazy, like ACCORD PICTURES
cuz i get a shitload of junkmail
Old 01-23-2003, 07:44 PM
I don't have any pitures yet but I may pretty soon. I'll hold on to your e-mail address and mail them to you asap. About the camber kit...The rear wheels are a lot easier. All you really need is a couple of thick washer's to put in the screw of your upper control arm. As for the front wheels you need to have a kit. The kit is around 100 bucks depending on what you buy. I'm not sure how hard it is to install. I'm guessing it's not too bad. So it is a little pricy but it's that or let your tires be worn improperly. Personally I have had my car lowered for about 2 or 3 months I guess and it's really not too bad on the tires. i don't have a lot of camber really. You might be able to pull it off. I haven't put on the front or rear camber kit yet. I'll prolly do the rear at least before I put on a new set of treads.
Old 01-23-2003, 09:47 PM
pimpstyles77 pimpstyles77 is offline
Send a message via AIM to pimpstyles77
i wanna get ibach shocks but i havent herd anything about them what should i get
Old 01-23-2003, 10:25 PM
I have Eibach Springs. I don't know if Eibach makes shocks/struts. I also have Tokico Premium Struts (blues). I had coilovers but I got rid of them because it was way too bumpy. So yeah if you want Eibachs get Eibach Sportline Springs and then some struts. Tokicos are good. KYB's aren't bad. You'll need to replace the struts if you want a good setup. The struts will end going bad anyway so I hear. Something about the fluids getting too hot. You get what you pay for I guess.
Old 01-23-2003, 10:30 PM
THANX^^ I THOUGHT THEY DID I GOT TOKIKO TOO I LOVE THEM THE BLUE SERIES. DAM I NEED MORE TORQUE TOO BUT THATS ANOTHER PROBLEM
coil over shock or no coil overs big white bufflo AMC 1 02-06-2025 01:22 PM
Coil Overs to replace stock coils and shocks 99 4WD Rodeo stantony1 Rodeo | Passport | MU 0 09-20-2010 03:28 PM
97 Safari turns over but won't start - ignition coil wires? icemuncher99 M Bodies 3 05-31-2010 06:03 PM
querstions about my first ticket Ultimate X Traffic Violations - U.S. only 4 03-24-2007 11:54 PM
about integra coil-overs daddys '88 - '91 Civic | CRX | Wagon | Shuttlee 1 07-24-2002 05:31 PM
