Old 12-06-2005, 11:08 AM   #1
klutz_100
klutz_100's Avatar
Squadron putty question
I tried searching but I couldn't find a good answer.
What is the difference between squadron Green and White putty?
Thanks in advance
Old 12-06-2005, 11:11 AM   #2
Ferrari TR
Not A Hoarder!
Ferrari TR's Avatar
Re: Squadron putty question
The color...
I think the white is a little finer.
SCCA 7, The lost Z
Ferrari TR is offline   Reply With Quote
Old 12-06-2005, 11:43 AM   #3
freakray
AF Modelrater
I've found the white to be coarser, personally I prefer the green.
AF User Guidelines
freakray is offline   Reply With Quote
Old 12-06-2005, 01:34 PM   #4
drunken monkey
Razor Sharp Twit
drunken monkey's Avatar
that's something i've noticed too.
there's no differentiation on the boixes that hold the stuff.
and er, white?
i think i have green or red to choose from.
drunken monkey is offline   Reply With Quote
Old 12-06-2005, 02:55 PM   #5
p9o1r1sche
Registered User
p9o1r1sche's Avatar
I found the white putty to be harder and more chalk-like (more crumbly and less flexible) than the green. I believe they both shrink alot. After a month or so, I can see the green putty has shrunk from the original shape.
p9o1r1sche is offline   Reply With Quote
Old 12-06-2005, 04:26 PM   #6
ConfederateInfidel
ConfederateInfidel's Avatar
Yeah, the green shrinks a lot, the white does some, never knew about the red. I prefer Evercoat automotive filler mixed with Bondo brand hardener.
^ Signature Line ^
ConfederateInfidel is offline   Reply With Quote
Old 12-06-2005, 07:21 PM   #7
druid_99
druid_99's Avatar
I've used Squadron White Putty for years now and I agree that it will break or chip and also shrink but I rarely had any of that problem... From the many cars that I've built, most of the time the putty stays and has no shrinking problem at all. I've never tried the red and green ones though.
What is understood need not be discussed
druid_99 is offline   Reply With Quote
Old 12-07-2005, 04:21 AM   #8
Q-DawgVFR
Yeah, white definately shrinks a lot. I now use automotive filler for all but the smallest of jobs. The Squadron putty is fine if applied very thin like a glazing filler on autobody repair. It seems best suited to filling small imperfections.
Q-DawgVFR is offline   Reply With Quote
Old 12-07-2005, 01:49 PM   #9
drunken monkey
Razor Sharp Twit
my bad.
i have to say that i've enver really looked at the tube for anything other than the "squadron" name.
the red one i was talking about IS the white putty.
slightly off topic but when i have a biggish spot that needs filling but also needs to be less brittle or somethin similar, i mix up a little batch of 'melted' plastic by disolving shavings of sprue into some plastic weld.
