Go Back   Automotive Forums .com Car Chat > Engineering/Technical > Tires and Wheels
Old 03-22-2005, 10:44 PM   #1
tetrahydro
Banned
nooby tire question
what do the three numbers describing tires each individually mean for example 215/35/18 compared to 225/40/18 thanks
tetrahydro is offline   Reply With Quote
Old 03-23-2005, 06:30 AM   #2
CapriRacer
Re: nooby tire question
Look up "Size" in Tire Rack's web site.
Then find a "Tire Size Calculator".
CapriRacer is offline   Reply With Quote
Old 03-23-2005, 04:12 PM   #3
curtis73
Professional Ninja Killer
curtis73's Avatar
The quick answer: section width, aspect ratio, wheel size. The section width is in mm, and is the width at the widest point of the tire (not the tread). The second is aspect ratio in %. If its a 40-series tire, that means the sidewall is 40% of the section width. The last one is the size of the wheel it fits.
Dragging people kicking and screaming into the enlightenment.
curtis73 is offline   Reply With Quote
Old 03-23-2005, 04:59 PM   #4
tetrahydro
Banned
Re: Re: nooby tire question
so then what size tire would you suggest if i wanted really low profile tires for 18inch wheels
Old 03-23-2005, 08:45 PM   #5
CapriRacer
In order to answer the "what size question", one needs to know what the year, make and model of your vehicle is as tire size is related to load capacity.
But a quicker way to get your answer is to look at your vehicle placard. That will tell you what the original tire size and inflation pressure was for that vehicle. The load index is there, too. and your new tires should be at least the same load index or larger. the vehicle placard is usually located on a doorpost or in the glove box.
Hope this helps.
