Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 04-17-2007, 11:15 PM   #1
Damnir
Is cruise control hard to turn on, or am I doing it all wrong?
I have an 04 GT2, I can't seem to get cruise control to work. It seems laughable, but I've read the book, and it doesn't work =(
The car has 100k on it, so I have to wonder if something is broken. Here's what I've read and what I think I understand.
Cruise won't work with TCS on right? If I am reading the book right (again), I need to press the TCS button on center console and I get the amber light with the car sliding (this means it's off right?).
Then, while driving I press the button in on the right cruise control lever, push it forward to set current speed, and that's it?
Oh, and this website rocks! Thanks to everyone who contributes.. Learning lots about the pings/knocks I am hearing from my car!
Although laughable, trying to diagnose if it's broken?!
Thanks!
Damnir is offline   Reply With Quote
Old 04-18-2007, 10:16 AM   #2
GPFred
Re: Is cruise control hard to turn on, or am I doing it all wrong?
In my 2000 Gp you have to slide the "On" switch to the "On" position first before the lock button will work. You also might check to see if the cable connection at the throttle is still connected. Mine had recently come off causing my cruise control not to work. You might also inspect the cruise control system in the engine compartment such as the cruise control cable and box. Good Luck.
GPFred is offline   Reply With Quote
Old 04-18-2007, 11:34 PM   #3
Damnir
Looks like I was on the right track. Thanks for the post, nothing is wrong with my setup. My problem was with traction control. I assumed by default it was off all the time unless I engaged it. Once I press TCS, it turns off (I never payed attention to the center console saying it was off). All I have to do then is move the lever foward to set the speed I want, move it down to engage, and then press the button in on the handle to start.
I guess it all makes sense after you figure it out like anything else.
=P
Old 04-19-2007, 03:55 PM   #4
04GTP
Send a message via MSN to 04GTP
weird mine works even with tcs on
2004 GTP oooh yea
04GTP is offline   Reply With Quote
Old 04-20-2007, 01:40 PM   #5
04GTP-WhatLAG?
04GTP-WhatLAG?'s Avatar
mine does as well, that is weird
2004 Pontiac Grand Prix GTP
Custom K&N Fenderwell Intake , 180° thermostat, 3" Down Pipe, High Flow Cat, DHP 1.0 PCM, 3.5" pulley, 1.9 Ratio Roller Rockers, 90# LS6 Valve Springs, AL104s, ZZP Motor Mounts, 17" American Eagle 192s, Magnaflow tips.
not just babies whine
04GTP-WhatLAG? is offline   Reply With Quote
