Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-07-2004, 05:19 AM
CKAMC CKAMC is offline
Send a message via AIM to CKAMC
general engine question
ok i have a 95 se-r with the sr20de sitting inside it. i wonder what engines i can upgrade to that will fit the current tranny and will out perform the 20de. please include specs or links. ty for your time
PS will it bolt in easy or will it take some work and it will fit in?
Lets see how far we can take it from stock
I am here to show the power of the SR20
Old 03-12-2004, 03:19 PM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
Re: general engine question
You have a few choices
A Front wheel drive SR20DET(205hp stock)
A front wheel drive SR20VE(190hp stock)
or bolt on's for your SR20DE
With the DET you could be running mid 13's in the 1/4 and with the VE you probably be running high 13's. If you're looking for an easy performance upgrade tho, just look into modding your DE. You're probably running about a 16 flat in the stock SE-R now and with a few good bolt-ons you can hit mid-low 14's. It's all about your budget. If you have less than $3500 or so to spend at a time, then just look into bolt-ons. Acceleration matching an S2000 isn't too shabby! PM if you want more details about mods and their effectiveness
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 07-21-2004, 03:23 AM
B14Boost B14Boost is offline
Send a message via AIM to B14Boost Send a message via Yahoo to B14Boost
Pulsar GTI-R would work too. Its an All wheel drive tranny, but will bolt onto the SE-R tranny. You would want limited slip though, otherwise, good luck with traction.
Old 07-21-2004, 05:06 AM
fugiot's Avatar
All SE-R's some with an LSD stock.
Don't make me ANGRY
Old 07-21-2004, 08:04 AM
200SXGTi-R 200SXGTi-R is offline
the stock lsd in the se-r tranny is no good its viscous and wears out after a few hundred miles. it only came up to 97. A SR20ve swap will only give you mid to high 14's with intake headers and exhaust a little more mods on it will give you high 13 and low 14 but expensive parts and hard to find.
Old 07-22-2004, 12:58 AM
fugiot's Avatar
hmm, I didn't think there was much difference in the times from B13 to B14. Cause a B13 with the VE will run around a 14.0 with no mods other than the engine itself.
Don't make me ANGRY
Old 07-22-2004, 10:33 PM
i doubt that, i know a few VE's , and the ones that run those numbers have mods. something is up with that engine
General Engine Swap Questions XGamesJ6 Cutlass Series 3 04-19-2008 11:25 AM
general engine lighting question jpucar Corolla/Matrix/Voltz 1 10-30-2006 12:59 PM
general engine related questions stevedashiak Yukon 1 02-10-2003 05:42 PM
