Go Back   Automotive Forums .com Car Chat > Ford > Taurus | Taurus Wagon
Old 02-01-2004, 04:27 PM   #1
arthuredyejr
Question #6 cyl. missfire dtc
I have a 96 mercury sable, 3.0, with 41,000 miles. I started car cold & let warm up, check engine light began flashing. Checked plug wire, & repl. plug. Is there any common probles or tsb's for this complaint ?
arthuredyejr is offline   Reply With Quote
Old 03-11-2004, 01:22 AM   #2
crazyjo4
Re: #6 cyl. missfire dtc
Yes, i have seen at least 4 occurances of the same exact thing u describe, including my own vehicle. Its a 2000 duratec. #6 was misfireing and causing the check engine to blink. in each case there was moisture found on and around the plug for that cylinder. Take out the coil, relplace the plug, and dry the hell out of it with a hair dryer or a heat gun. Once completly dried you should be fine. Most likely there is water somehow in that #6 cylinder. I was able to fix it by drying it out and switing #5 with #6 just to see if it was the coil or not, it turned out that the coil was fine, and it was the moisture thatw as casuing the misfire.
crazyjo4 is offline   Reply With Quote
missfire 99 cirrus v6 2.5l carax Cirrus 2 07-11-2009 12:38 AM
'97 Mercury Cougar #1 Cyl Missfire deanl Cougar 2 08-01-2008 09:15 PM
Missfire on cyl 5 on a 3.5 vpracer Concorde 8 06-10-2007 10:18 PM
97' Z24 cyl 2 and 3 missfire??? ryanbode Cavalier Problem Diagnosis 1 06-03-2007 09:15 AM
missfire #1 cyl Gary Richardson Escort 4 04-24-2005 05:32 PM
