Old 12-06-2001, 02:35 PM   #1
Chris_McCracken
AC lift install question
What size pickle fork do you need to remove the upper A-arm ball joint? Any other odd tools/methods I should know about for installing AC lift?
Chris_McCracken is offline   Reply With Quote
Old 12-06-2001, 04:01 PM   #2
VaderX
Send a message via AIM to VaderX
I don't have the ac lift but I still had to remove that ball joint on mine. The one thing I believe many underestimate is how hard you really have to hit the pickle. I couldnt get it to budge until I really laid into it. I had my brother hold the fork and then I grabbed the hammer with both hands and really put my back into it. A couple of super hard wacks and it popped off. On the other side I didn't even waste my time withe the lighter hits. I went full bore right away and it popped off in 4 hits.
VaderX is offline   Reply With Quote
Old 12-06-2001, 04:16 PM   #3
superjens
superjens's Avatar
What about the blowtorch method? Heat the sucker up a bit first, loosen the joint (from the expanding metal).
superjens.com
I like saying aboot.
superjens is offline   Reply With Quote
Old 12-06-2001, 06:36 PM   #4
VaderX
Well with the abs line the cv joint boot and other plastic pieces in the area I would hesitate to use a torch near there.
Old 12-06-2001, 06:42 PM   #5
Chris_McCracken
Well, the torch could be aimed precisely enough to only heat what was needed, but I don't have a torch yet. Does anyone know what size pickle fork for the upper A-arm joint? I don't want to buy a few and only use one, as I'd probably never use the others.
Old 12-06-2001, 07:46 PM   #6
xoc
xoc's Avatar
Your brother is very brave...
The best technique is to rap both sides of the spindle at the same time with 2 hammers. This will cause harmonics to loosen the press fit. It should pop right out after that.
Regards,
Ian
xoc is offline   Reply With Quote
Old 12-17-2001, 09:58 PM   #7
Matt Peckham
Matt Peckham's Avatar
Send a message via AIM to Matt Peckham
Stormy bought a smaller picklefork than the one supplied with the AC lift. After an hour or so of trying to get it off with the AC pickle, it took one good blow with the CORRECT pickle.
Maybe I can get him to shed some light on the subject.
Matt
Matt, the guy with the big ugly rack on his X.
Matt Peckham is offline   Reply With Quote
Old 12-18-2001, 09:26 AM   #8
Chris_McCracken
I'd have to agree with that. After beating the shit out of a "generic" sized pickle fork (none included), I went up to Sears Hardware and got a "pickle fork kit" that included several sizes. Grabbed the smallest one, and it took about three whacks and the ball joint popped right off. Anyone having camber problems with their AC A-arms (as in you can't get the top in far enough)?
Old 12-19-2001, 08:59 AM   #9
Stormy
Stormy's Avatar
Matt's right
When I installed my AC lift I was refering to Mosi's instructions. Everyone who had the lift at the time was saying that it was very difficult to get the balljoints off. .This is not true. If it is hard to seperate the balljoints, you're using the wrong sized picklefork! After about 1/2 hr of beating the crap out of the drivers side and getting nowhere, I borrowed the one size smaller picklefork (I don't remember the exact size) from pepboys. One swing on the drivers side and 2 on the passengers side
As for the camber issue... Yes, I was having slight camber problems. It was a combo of equal tension on the t-bars and leaving enough space between the bumpstop and pad.
Stormy is offline   Reply With Quote
Old 12-21-2001, 01:28 AM   #10
XMan9
XMan9's Avatar
Exclamation Hey!
you guys shouldn't ever heat up ANY steering or suspension part. it will ruin the temper of the part and maybe become brittle. steering parts are made of a higher grade steel. don't do it. unless of course you are going to toss the old parts or don't heat it cherry red. that is a no-no to front end mechanics. be careful...
X Was Here :grey:
www.geocities.com/xterra9
XMan9 is offline   Reply With Quote
Old 12-21-2001, 08:03 AM   #11
Elroy
Here is a pic of the two different pickle forks that Chris and I used. The one on the left we purchased first from AutoZone. As you can see in the picture, it ended up bending out. The one on the right was bought at Sears Hardware, a little more expensive, but worth it. We used the smallest fork in the set and it only took a couple good whacks.
Elroy is offline   Reply With Quote
Old 12-21-2001, 11:59 AM   #12
FSRBIKER
FSRBIKER's Avatar
That kit from Sears is excellent, it even includes an attachment for use with an air hammer. Elroy how did you make out after speaking with Nissan Mike?
Todd AKA FSRBIKER
EOE
www.Extreme4x4Parts.com
FSRBIKER is offline   Reply With Quote
Old 12-21-2001, 12:48 PM   #13
Elroy
Not very well. Everything seemed worse off after I started to try the things he suggested. So I just took it to an alignment specialist and he cleared most of it up. The guy at the shop mentioned that the passenger side A-Arm seems to be about .5 too long. So my camber is just a tiny bit off on that side, but nothing as noticable as before.
Old 12-21-2001, 02:22 PM   #14
Stormy
Stormy's Avatar
My a-arm is the same. One is a little off. I'll post a picture tonight when I get home.
Old 12-21-2001, 02:58 PM   #15
Elroy
I glad I'm not the only one with this problem.
torsion bar lift/turn up, lift kit questions and facts markhs2 C/K 13 03-29-2007 05:59 PM
2" body lift installed Antitree_hugger Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 32 04-20-2005 01:54 PM
3" body Lift Installation jdugan C/K 1 01-24-2004 04:44 PM
SLR 2" body lift installed gothamist Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 40 08-09-2001 03:41 PM
AC lift installed! Mosi Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 22 07-11-2001 05:30 PM
