Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 10-15-2003, 11:23 PM   #1
lordfritter
"ETS Off" Light and "Check Engine" Light stay on!
During a day of long driving, (100 miles here and 100 miles there), half way back to my house, my 'ETS Off' and the 'Check Engine' Lights came on. Now, I must ask, Why!? The car seems to be running just like it did long before the lights shone in my dash (except for the fact that the ETS won't come back on). How can I figure out what's causing this... without taking the car to the GM dealer near me and getting taken for my last few pennies...?
lordfritter is offline   Reply With Quote
Old 10-16-2003, 07:25 AM   #2
GMMerlin
I know stuff
GMMerlin's Avatar
Re: "ETS Off" Light and "Check Engine" Light stay on!
The PCM has seen a fault in the system and has set a trouble code...could be a sensor problem, wiring problem.
You will need to have the code pulled out of the PCM and have the fault diagnosed and repaired.
Some of your autoparts stores have code readers.
Let us know what the code is and we can go from there.
Information provided by a dealer tech...and didn't cost you a dime
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
GMMerlin is offline   Reply With Quote
Old 10-16-2003, 09:39 AM   #3
Leah525
Autozone can run the codes for free. My Sister had the same problem and the problem with hers was it was misfiring in the 1st cylinder. She waited to get it checked out and now cannot get it fixed.
Leah525 is offline   Reply With Quote
Old 10-16-2003, 06:51 PM   #4
lordfritter
Thanks for the advice, guys. I'm going to check it out tomorrow and see what you all think.
Old 10-16-2003, 07:34 PM   #5
Flatrater
Main GM Guy
Flatrater's Avatar
Re: Re:
Seems like a lot of free dealer advice is given out here in this forum!!
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Flatrater is offline   Reply With Quote
Old 10-21-2003, 06:01 PM   #6
goldbull
Just had this happen to our 96 GA this week. Turns out the back O2 sensor is to blame. Seems it shorted out (check engine light) and took out the ETS in the process.
goldbull is offline   Reply With Quote
Old 10-22-2003, 02:51 PM   #7
rowser
My 96 Grand Am does this same thing, usually first thing in the morning, about once every couple months or so. The car seems to run rough, like it's getting to much fuel, then clears itself up and runs fine. I can get the "check engine light to go Off and the ETS to function again by disconnecting the battery for a few minutes. Then it's back to normal.
rowser is offline   Reply With Quote
Old 10-22-2003, 04:05 PM   #8
GMMerlin
I know stuff
GMMerlin's Avatar
Re:
The problem is you are not fixing the problem but just masking it by turning off the light.
The best thing is to have the problem diagnosed and repaired by a knowledgable and trustworthy certified technician.
GM WCT
PM Me for details
Old 10-25-2003, 09:47 AM   #9
Bob Pitchford
Send a message via Yahoo to Bob Pitchford
Re: 97 Grand Am 2.4L - Check engine & ETS lights
97 Grand Am SE 2.3L engine 75,500 miles
Engine will stall one a day when first driven, usually at a stop sign. After restarting, the check engine light and ETS lights will go on steady. The engine will run fine for a few days and usually after a fill of gas, the lights go out.
Have made the mistake to take it into the local GM dealer. The dealer said the code pointed to an ignition problem. The car was returned after a $245.00 tune up. The process repeated itself after 1 day. The car was retuned to the dealer after 2 days, (light reset on the way to the dealer after filling with gas) and was told that injector #2 needed to be replaced. The car was returned with a new injector for $250.00
The next morning the car quit at the stop sign and the lights came on again. I've added more gas but the light is still on. Any Ideas, the car has 75,500 miles on it.
I thought I might take it to the local AutoZone to see if the could try a scan tool on it.
Bob Pitchford is offline   Reply With Quote
Old 10-25-2003, 05:07 PM   #10
Flatrater
Main GM Guy
Flatrater's Avatar
Re: Re: 97 Grand Am 2.4L - Check engine & ETS lights
Will need a code number to help you out!
ASE Master Tech
ASE Advanced L1
GM Master tech
Old 10-26-2003, 12:18 PM   #11
Bob Pitchford
The code was listed as P0302 #2 misfire. The guy at autozone asked if the plugs were changed with the tune up. Although it was not listed on the workorder, I pulled the plugs and they were obviously new. I swapped the two outside plug boots with the two inside ones. (thinking that if there was a problem with the boot, the code would change) I also noticed dirt in the ignition driver connector. I cleaned the connector, replace it, and started the engine. The Ck engine light was still on. I then disconnected the battery negative terminal for a minute. Restarted the engine, and the light went out for a short time, came back on again, and after about 2 miles driving the light is off.
It now has 3 days driving and about 70 miles with the light off. Today the engine stalled at a stop sign and after restart the check engine light & ETC light came back on again. A trip back to Autozone and their code reader show the same code, P0302 #2 misfire.
Any other suggestions?
Old 04-18-2005, 05:09 PM   #12
frekey
frekey's Avatar
the same happened to my car and it ended up being the tranny!
frekey is offline   Reply With Quote
Old 04-18-2005, 05:20 PM   #13
Mr. Luos
Firebird Guy
Mr. Luos's Avatar
Re: Re:
Your tranny was causing a misfire on Cylinder #2??
I would check the coils.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Mr. Luos is offline   Reply With Quote
"Trac Off" and "Check Engine" light keeps coming on... LtCmdrFlygirl Cavalier Problem Diagnosis 2 11-02-2005 04:36 PM
"Check Engine" and "Check Trans" lights both came on after a gas fill-up dbarak Amigo 2 04-05-2005 09:11 PM
"Check Engine" Light ON/OFF arks Grand Cherokee | Grand Cherokee SRT8 5 09-17-2004 02:44 AM
