Old 09-27-2001, 12:20 PM   #1
Heep
Heep's Avatar
Send a message via AIM to Heep Send a message via MSN to Heep
Sanding
Question from a newbie.....
Should I sand the body before spraying?
________________________________________
Mark Brown
1991 Volkswagen Jetta (1.8L I4/5-speed/FWD)
Heep is offline   Reply With Quote
Old 09-27-2001, 12:22 PM   #2
DVSNCYNIKL
R.I.P. DAD 3/25/11
DVSNCYNIKL's Avatar
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
I haven't built models in a long time, but I never sanded the body completely. Just were I was going to do something custom and wanted to smooth out a surface. On some models that I painted though, I would prime it, helps the paint stick better and in some cases, the color shows better.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
DVSNCYNIKL is offline   Reply With Quote
Old 09-27-2001, 01:13 PM   #3
Jay!
Horizontally Opposed
Yes. You should wash the bare plastic with warm water and dish soap, then sand it with a reasonably coarse sandpaper. I use 1800 grit for this first sanding.
The A-Number-One Reason: molding lines. A car body is cast from a complex multi-part mold, leaving mold lines that may not be evident at first, but will surely get in the way when you go to polish the final paint job.
I learned this the hard way on an MR2 I built. I thought I had removed the mold lines, but when I was polishing at the end I found the the mold lines on the rear of the car were hidden in the trunk panel lines. They didn't lie flush with the adjacent panels, so I ended up taking paint of the edges of the trunk.
Then, as DVS says, a good coat of primer is called for. Then sand the primer to find any remaining flaws. This will be easy, because where there are raised lines, you will sand through the primer. Sand these down smooth, then you'll be ready to finish priming, and start painting.
Hierarchy of Subaru:
(Click to see mine!)
Jay! is offline   Reply With Quote
Old 09-27-2001, 09:16 PM   #4
YellowMaranello
YellowMaranello's Avatar
Send a message via AIM to YellowMaranello
how do i get bubbles out of already dried paint? do i just let it dry, sand em down, and the paint again?
YellowMaranello is offline   Reply With Quote
Old 09-27-2001, 09:33 PM   #5
Jay!
How bad are the bubbles? Are they open like pock marks, or are they lumps under the surface?
Old 09-27-2001, 09:56 PM   #6
Heep
Heep's Avatar
I just hate it when a hair dries into the paint.
Mark Brown
Old 09-27-2001, 11:45 PM   #7
primera man
"P-Man"
primera man's Avatar
Yes you well have to sand them out to get a good finish.
I have found that the bubbles can be caused by spraying the car with too much paint (too thick)
If you see them appear as soon as you have finished spraying, try pricking them with a needle if there are not to many. Hopefully they will run in with the rest of the wet paint.
View All My Models Here.
primera man is offline   Reply With Quote
Old 09-28-2001, 12:07 PM   #8
S Brake
Ferrari Guy
S Brake's Avatar
this is kind of an odd question coming from someone that has done lots of models. I have never primed, sanded, polished or any of that. i'm just wondering what kind of primer to get, how to polish the paint (is it like waxing??????) thats basically all i need to know, i want my R34 to be GREAT!
The contents of this post may be fictitious.
S Brake is offline   Reply With Quote
Old 09-28-2001, 12:30 PM   #9
Guiddy
Guiddy's Avatar
All you need to know is in my thread on the WRX!
Be wary of polishing too much paint off, and ending up looking at the basecoat or primer!
A situation where only experience will teach you how much is too much unfortunately!!!
But yeah, same idea as waxing really!
Guiddy is offline   Reply With Quote
Old 09-28-2001, 06:09 PM   #10
primera man
"P-Man"
I use Tamiya Fine Surface Primer
After finishing painting the finish coat i use Tamiya Rubbing Compound then finally Tamiya Modelling Wax.
The end product is awesome when finished.
The wax can be used over decals too, it takes away any water markes and leaves a nice gloss on the decal.
Old 09-28-2001, 06:15 PM   #11
primera man
"P-Man"
Sometimes to, if they are not to bad, give it a light sand with 1200 grit paper(wet n dry) and very lightly try and sand them out.
Then use Tamiya Rubbing Compound, this will bring the gloss back out and take away the sanding marks if done correctly.
If the bubble has "pitted" the paint, then you will have to paint again.
But try the above first.
Old 12-05-2001, 08:29 PM   #12
kris
Off playing with fire.
kris's Avatar
So, after you sand the first coat of primer, and respray. Do you sand that other sprayed coat as well? Or leave it, then move on to the color?
kris is offline   Reply With Quote
Old 12-05-2001, 09:31 PM   #13
primera man
"P-Man"
Move on to the colour
Old 12-06-2001, 07:38 PM   #14
Jimster
Here for the pussy, man.
Jimster's Avatar
Send a message via ICQ to Jimster Send a message via AIM to Jimster Send a message via Yahoo to Jimster
Question
I can see the importance of removing mould lines, but Primer???? Is it ABSOLUTLEY ESSENTIAL that I use Primer, or is Primer only if you want a perfect finish??????
Check out my Pride and joy in AF- and discuss your favourite Alfa Romeo
2007 Audi A4 3.0 TDI Le Mans
Jimster is offline   Reply With Quote
Old 12-06-2001, 07:41 PM   #15
kris
kris's Avatar
Yes, primer helps. I can tell you that. Here I have two seperate cars, done two seperate ways. One with primer, one without. It looks 10 times better with primer.
