Go Back   Automotive Forums .com Car Chat > Dodge > Dakota
Old 05-23-2012, 11:00 PM   #1
jdb0722
2003 Dodge Dakota 3.9-v6 loss of power
4x4, Quad Cab, 78,000 miles. Any suggestions would be great. Had the transmission rebuilt, no help, had the governor sensor and solenoid replaced, no help. Had the muffler changed to a magnaflow, helped a little then changed the intake air system to a airaid system with throttle spacer, helped a little. Thinking about a performance chip, but so many out there don't know which one to get!!! Superchip, Gforce, Jet Line, etc etc etc... is it even worth getting a chip??? PLEASE HELP
jdb0722 is offline   Reply With Quote
Old 08-04-2016, 06:58 PM   #2
clutch492
ASE Master Tech
Re: 2003 Dodge Dakota 3.9-v6 loss of power
Might want to look at the catalytic converters to see if they are plugged. I have seen them fall apart inside and chunks of the honeycomb will get pushed back, by the exhaust flow, and block the exhaust. Hope this helps.
clutch492 is offline   Reply With Quote
Old 08-04-2016, 07:12 PM   #3
bellaCuba
bellaCuba's Avatar
If you have loss of power, you need to repair the issue 1st. Adding a chip is only going to make things worse.
Start with basic checks or maintenance such as spark plugs, ignition wires, or look for pending codes in the system. Just because a check engine light is not on, doesn't necessarily mean there are no issues.
~Cuba~
bellaCuba is offline   Reply With Quote
95 Dodge dakota, 3.9 V6 two weel drive, Failed NOX, to high Richter1234 Dakota 5 11-03-2010 12:03 PM
89 dakota w/ 3.9 v6 rumjy Dakota 4 01-23-2010 08:16 AM
1987 Dodge Dakota 3.9L V6 Rear end tag number HELP! knjwells Dakota 2 08-30-2009 05:39 PM
3.9 V6 Backfire/power Loss xs313 Dakota 0 06-16-2007 02:20 PM
93 Dodge Dakota 3.9 A/C problems bmayer13 Dakota 1 08-12-2004 05:01 PM
