Old 04-11-2012, 02:28 PM   #1
pairof97blazers
99 lumina transmission problems
99 lumina, when first started, transmission will go into gear and i can move the car, but after about 3 or 4 minutes, it will not move the car at all. any thoughts as to whats wrong, a bit more specific than Trannys toast please
pairof97blazers is offline   Reply With Quote
Old 04-11-2012, 07:29 PM   #2
maxwedge
A990 racer
Lightbulb Re: 99 lumina transmission problems
Well without seeing what may be laying in the bottom of the pan and/or doing a pressure test what would you like to hear, you certainly have an overhaul ahead of you!
maxwedge is online now   Reply With Quote
Old 04-11-2012, 07:44 PM   #3
FishFind
One Hot Shot
check fluid level and color
FishFind is offline   Reply With Quote
Old 04-11-2012, 11:39 PM   #4
pairof97blazers
fluid level is just under full mark, a little dark but still has reddish tint (full flush 50 k ago) no burnt smell, sounds like the pump is cavitating. im gonna change the filter tomorrow and see whats going on. Stay posted for PICS
Old 04-12-2012, 11:58 AM   #5
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Usually means the pump is shot, or a seal is blown so badly that it only gets enough fluid pressure to operate when the fluid is cold and heavy....once it warms, fluid weight drops and pressure goes below threshold to operate correctly...
...empty gun rack.
Old 06-14-2012, 04:39 PM   #6
dimperdoo
my '98 does this exact same thing - bump...
dimperdoo is offline   Reply With Quote
Old 06-15-2012, 10:51 AM   #7
maxwedge
A990 racer
Welcome AF. Ok, so the above advice applies to you but as you see there is no response as to the resolution.
The Following User Says Thank You to maxwedge For This Useful Post:
dimperdoo (06-15-2012)
Old 06-15-2012, 05:32 PM   #8
dimperdoo
Is there an aftermarket, handheld code reader I can pick up reasonably that will read the transmission codes?
kind of a trick getting the car from my rural location to a shop.
Just confusing w/ this issue because the transmission does work normally for the few minutes after you start the car -and, it will do it again if you turn it off and start it again - lol
Old 06-15-2012, 10:21 PM   #9
maxwedge
A990 racer
Pcodes for the trans usually show up with a normal high line scanner, for diagnostics you need a real professional scanner.
Old 06-18-2012, 01:52 AM   #10
dimperdoo
Old 06-18-2012, 11:27 AM   #11
maxwedge
A990 racer
That will read basic codes, not much chance you will get tanas codes unless the cel is on, very basic unit.
Old 06-19-2012, 10:17 PM   #12
Tech II
There are some good deals on low end scanners(that also read engine data, as well as read/clear codes, check flags) at Amazon.com........
Old 06-20-2012, 05:46 PM   #13
dimperdoo
OK, so what I have now is a "snap-on diagnostics scanner mt2500"
I hooked it up and, it said the car was "ok to drive" lol
Don't know much about what I'm looking for but one thing I did notice was trans fluid volume was @ ~2.4 while the transmission worked but, was @ 1.99 when the tranny stopped working. still "ok to drive"
Old 06-20-2012, 08:20 PM   #14
maxwedge
A990 racer
I seem to remember the MT2500 had an accessory trans cartridge for bi-directional diagnostics, the scanner cannot tell all, slipping is slipping something diagnosed during a road test.
Old 06-23-2012, 05:13 PM   #15
dimperdoo
is the fluid volume info significant though?
I guess my next step is to pull the pan and see what the fluid looks like/if there's debris in the pan...
1996 Chevy Lumina ignition problem! RedAzureSkye Lumina 2 05-29-2011 09:48 AM
98 Lumina Transmission Problem... MSimpson Lumina 5 10-09-2007 07:30 AM
1991 lumina Transmission problems?? bobbarker123 Lumina 1 09-16-2007 03:06 AM
97 Lumina Transmission problem frank schaefer Lumina 4 11-04-2005 08:02 PM
