Go Back   Automotive Forums Car Chat > Chevrolet > S-10
Old 02-17-2011, 11:18 AM
BeatleBaily's Avatar
BeatleBaily BeatleBaily is offline
Exclamation no power up hill
It runs good on flat ground but when I start to go up hill it feels like I'm pulling a cement truck. Giving it gas does nothing.
1983 carb. 2.8 v6 manual trans.
Millage unknown, broken gauge.
add your here...
Old 02-17-2011, 02:05 PM
j cAT j cAT is offline
Re: no power up hill
add your here...
remove the O2 sensor, drive with the hole open....could be bad converter if it does run better with the hole open..could also be a pluged muffler..
Old 02-17-2011, 03:51 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Classic converter failure symptom - no power !
" Sometimes I grow so tired "
The Following User Says Thank You to oldblu65 For This Useful Post:
BeatleBaily (02-17-2011)
Old 02-17-2011, 05:37 PM
I ordered a new cat.
Old 02-17-2011, 06:23 PM
did you test out the restricted exhaust which I suggested ?
lets say I am correct the exhaust is restricted. the converter has melted down/clogged with carbon. first you must insure the engine is running properly.
If your carb or the fuel evap/vent system is defective this can cause the new converter to be damaged by trying to consume all the unburned fuel that this defect may create.
I have seen this before. looks like a glowing fire pit!
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 02:44 PM
88 Caprice Power Issue mbronzino Caprice 3 04-29-2009 12:21 AM
97 7.3 power not what i used to be 86troopercrzy E Series 2 03-21-2009 12:03 PM
Loses power under acceleration MikeS144 Metro 13 02-15-2009 08:56 PM
J-2 Rochester Tri-Power Ragtop_Renegade Oldsmobile Classics 2 02-13-2009 05:40 PM
Tags
power
