Old 12-01-2010, 06:12 PM   #1
robans
96 lumina wont start
I recently purchased a 96 lumina when I put the key in it dings. And d the fuel pump starts clicking. It continues to clicking as long as the batterys hooked up regardless. Of wether or. Not I have the key in. Once I turn key to the on possition dinging stops and clocks comes on flashing but. Insterment. Panel does nothin at all . Turn signal and windshield wipers also fail to work as well as auto locks.bits as if I have no battery on but batterys new. When I try cranking still nothing. plz. help
robans is offline   Reply With Quote
Old 12-01-2010, 07:46 PM   #2
maxwedge
A990 racer
Re: 96 lumina wont start
Tough to understand what you are saying here, but anyway does the security lite on the dash stay on?
Old 12-01-2010, 07:59 PM   #3
robans
no lights at all come on except clock on radio gauges dnt wrk either
Old 12-02-2010, 04:33 PM   #4
maxwedge
A990 racer
Look for blown master fuses under the hood or bad cable connections, to start with.
Old 12-02-2010, 04:44 PM   #5
robans
Checked all fuses and relays they're good connections seem fine as well
Old 12-03-2010, 01:09 PM   #6
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Fuel pump shouldn't click. You are hearing relay chatter, maybe?
...empty gun rack.
Old 12-04-2010, 12:31 AM   #7
robans
Its kind of a clicking sound I thinks its the fuel pump not sure not the one in the tank its connected to the trottle body
Old 12-06-2010, 09:12 AM   #8
jeffcoslacker
Sounds like the IAC motor chattering or something.
You may just have a bad ground...try hooking a jumper cable from the neg side of the battery to something bare metal on the engine and see what it does....
...empty gun rack.
Old 12-08-2010, 06:31 PM   #9
robans
Did that and got sparks... also replaced starter now when I hook up battery I get sparks and starter spins.. short somewhere?
Old 12-10-2010, 08:16 AM   #10
kevinb70
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
The ignition switch itself.... from your first post it sounded like you were getting weird issues by just inserting the key without turning it.
1999 Dodge Ram 1500 2WD 5.2L NV3500
1998 Chevy Lumina 3.1L (2010 DIY intake/head job, 2011 DIY A/C replaced, ran like a top til I sold it in 2014)
1999 GMC Sierra 4.3L
2014 Toyota Prius Four
kevinb70 is offline   Reply With Quote
96 chevy lumina wont start suzette Lumina 1 12-20-2004 08:00 AM
90 lumina wont start after battery change... crksboye23 Lumina 2 10-12-2004 03:28 PM
92 Chevy Lumina Wont Start T[][]V[]BO Lumina 1 07-11-2004 04:39 PM
92 lumina wont start mikevan Lumina 1 02-22-2004 04:39 PM
lumina wont start please help cornob Lumina 6 11-24-2003 12:11 PM
