Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-26-2009, 07:46 AM   #1
Cavalier9696
Cavalier9696's Avatar
Send a message via Yahoo to Cavalier9696
Unhappy 95 rs clutch promlems
Not sure if clutch is leaking or what. But I have checked the lines to the clutch cylinder with no leaks. I had my buddy push on the clutch while looking and couldn't find anything wrong. I can bleed it and the clutch gets good and tight. But only for a few days.
At first I thought it may be a faulty seal around the cap cause my radiator cap was blowing water out, so I thought this might be the same. I can pour fluid in the canister and in a few days it's empty. There is no leaks that I can see but the fluid is going somewhere.
Could it be a bad Master cylinder?
Thanx.
Cavalier9696 is offline   Reply With Quote
Old 11-26-2009, 09:02 AM   #2
david-b
Dave is THAT guy
david-b's Avatar
Re: 95 rs clutch promlems
So the clutch goes soft after a couple days and you're losing coolant? The 2 don't tie together at all.
For the clutch, the master and slaves go bad after a while. If it's not leaking anywhere, it could be one of those. Check inside the car to see if there's an fluid on the rug by the pedal and firewall. Lastly, check the hose at the clutch fluid reservoir that comes off the bottom of it. My hose became brittle a couple years back and got a very tiny hole in it.
It's a good idea to replace the master/slave when they get old anyways.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
david-b is offline   Reply With Quote
Old 11-26-2009, 09:18 AM   #3
SilvrEclipse
Holset powered 420a
SilvrEclipse's Avatar
Send a message via AIM to SilvrEclipse
You deffinately have a leak somewhere. It must be very small otherwise you wouldn't be losing any fluid. Take the boot off the slave cylinder and check for leaks there. Also check inside the car like Dave said, these are where most start to leak. I would go ahead and replace both if you can afford it. I would also replace the rubber line, I got a nice SS one for about 20$. You can buy rebuid kits for both the master and slave cylinder which will save you some cash.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
SilvrEclipse is offline   Reply With Quote
Old 11-26-2009, 12:23 PM   #4
Cavalier9696
Thanx for the replys.
Later today IM going to check all. I bought the car as a junk car and have been rebuilding it. Just weeding out all the problems.
Old 11-26-2009, 12:32 PM   #5
Cavalier9696
Found it. There is fluid all over the fire wall above the clutch pedal. So that means I have to replace the whole thing? Hose, master, slave etc?
Old 11-26-2009, 12:55 PM   #6
ned032002
ned032002's Avatar
Just the Master cylinder needs replaced if there's fluid inside the car near the pedal.
If you want a slightly stiffer pedal, then go w/ a SS clutch line that connects at the slave but it's not a necessity.
ned032002 is offline   Reply With Quote
Old 11-26-2009, 05:53 PM   #7
SilvrEclipse
Holset powered 420a
Just the master is bad, I would go ahead and replace it all while you in there. The car is almost 15yrs old, the slave cylinder will fail in the near future. I think you can rebuilt it for like 12$.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-27-2009, 03:29 AM   #8
ned032002
ned032002's Avatar
When I redid all of mine last year, I found out that NAPA had the best prices for the master and slave. Plus there a lot easier to deal with.
Old 11-27-2009, 08:05 AM   #9
Cavalier9696
K thanx.
Ya IM going to go ahead and replace it all. Is rebuilding it pretty ez? What price am I looking at if I don't rebuild? I found one on ebay brand new for $41.95. I would call but everything is closed cause of holiday.
Old 11-27-2009, 05:02 PM   #10
SilvrEclipse
Holset powered 420a
Sounds about right, you probably could replace the slave and master cylinder for about 80$. I have never rebuilt any of these parts but the slave cylinder comes apart easily but not so sure on the master. It shouldn't be to hard tho.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-27-2009, 05:47 PM   #11
ned032002
ned032002's Avatar
I would just buy new, too much of a hassle to rebuild especially if it's inexpensive to just replace.
Old 11-28-2009, 02:43 PM   #12
Cavalier9696
K thanx. Just going to buy and be done with it.
Old 12-07-2009, 04:35 PM   #13
Cavalier9696
Exclamation Re: 95 rs clutch promlems
K ran into a problem. The new master cylinder is not pumping fluid at all. When I put the and old one side by side, the rod in the old one was alot shorter.
I can screw the end that goes to the clutch pedal as far as it will go and it still wont pump. I know this is the right master cylinder but why is the rod so much longer than the old one? It didn't look like the old one was cut. There about a full inch difference. With the old MC it only took like 2 minutes to get the clutch pedal to tighten up. I been pumping on new one for 10 minutes. It wont even bleed.
Old 12-07-2009, 06:42 PM   #14
ned032002
ned032002's Avatar
Can you swap the rod from the old one and make the new one work? I had to use the rod from my old slave cylinder to make the new one work. Any pics?
Old 12-08-2009, 02:45 AM   #15
Cavalier9696
I'll take some pics today. Have to take the new off again. I looked to if i could swap them, but i have no clue in how to do it. Scared IM going to mess something up. Think I can just cut the rod to match the old one and go with it?
