Go Back   Automotive Forums .com Car Chat > Toyota > Sienna
Old 06-14-2002, 12:45 PM   #1
pghphil
Help needed in programming Keyless remote for 2002 Sienna
I need to program an extra keyless entry remote for a 2002 Toyota. Any help will be greatly appreciated.
Thanks, Phil
pghphil is offline   Reply With Quote
Old 07-03-2002, 12:37 PM   #2
stevenleevo
Keyless remote programming for Sienna
:rocket: I am in the same situation. If any one know how to program the remote for Toyota Sienna. Please help.......
sl
stevenleevo is offline   Reply With Quote
Old 10-31-2003, 10:49 PM   #3
r8tedg
I have a 2001 Sienna XLE that I have just purchased a new remote for. I need programming instructions as well. Found some instructions for Camrys but they don't seem to work for Siennas. Any help appreciated.
-Paul-
r8tedg is offline   Reply With Quote
Old 11-29-2003, 06:16 PM   #4
Big Yellow Monkey
I bought some remotes off of ebay for my 03 sienna, and they came with programming instructions. I figure I'll share them with y'all... The instructions are as follows:
1. Start with the following conditions:
a) Key is out of the ignition
b) Driver door is open (all other doors are closed)
c) Driver door is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a)Using the power lock/unlock switch on the driver's door (with the driver's door still open and unlocked), perform 5 lock/unlock cycles starting with lock. A lock/unlock cycle consists of pressing the power lock switch, followed by pressing the power unlock switch on the driver's door panel. Use an even pace and try to go relatively fast.
b)Close, then open, the driver's door.
4. Perform these steps within 40 seconds:
a) Using the power lock/unlock switch on the driver's door, perform 5 lock/unlock cycles starting with lock, as you did previously.
b) Turn the ignition to "ON" (as far as you can go without cranking your engine), then back to "OFF".
c) Again, turn the ignition to "ON" (as far as you can go without cranking your engine), then back to "OFF".
d) Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (lock then unlock) automatically, indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a) Press the lock and unlock buttons on the transmitter (the remote) simultaneously for 1 second.
b) Immediately after letting go of the lock and unlock buttons, hit the lock button by itself and hold it for 2 seconds. Within 3 seconds, the door locks should cycle (lock then unlock) once indicating successful programming. If the door locks don't cycle, or cycle twice, repeat steps 6a and 6b, as this means the remote has not been accepted.
c) Repeat steps 6a and 6b for each transmitter that will operate the vehicle, including any old transmitters.
7. Close driver's door.
There ya go. Just a couple pointers.
First off, notice the bold in step 6 c). You have to repeat 6 a) and b) for EVERY remote, both your old ones that were already working, and your new one(s). And you have to do it before closing the driver's door in step 7.
Second, don't test your remotes until you've completed step 7. Then go ahead and test all of them. If you press one of the buttons on the remotes before having completed everything and closing the driver's door, the programming will not be successful.
I programmed my 2 new remotes, and then my old ones stopped working. Sure enough, I didn't read the instructions properly. I had to program those 2 and my old 2 all together. They all work perfectly now.
Spread these instructions around. I remember looking for them and not being able to find em anywhere.
Oh, and enjoy!
-Biggie!
Big Yellow Monkey is offline   Reply With Quote
Old 01-10-2004, 09:11 AM   #5
shah8826
Angry 1999 sienna keyless remote program inst
Does this instructions in previous message by big yellow monkey work for 1999 sienna? If not, does some have instructions for programming the keyless remote for a 1999 sienna that they can post? Thanks.
shah8826 is offline   Reply With Quote
Old 01-10-2004, 12:27 PM   #6
Big Yellow Monkey
Should work for 99-03. The actual remotes for a 1998 sienna (first year of sienna I believe) are a different remote altogether, as are the remotes for the 2004 siennas. But for 1999-2003, they're all the same. These instructions should work perfectly.
Lemme know if you have any problems.
-Biggie!
Old 04-15-2004, 09:42 PM   #7
aich
Re: Help needed in programming Keyless remote for 2002 Sienna
-Paul-
I also have a 2001 XLE and the direction from Big Yellow Monkey did not work for me. Did they work for your XLE?
Peter
aich is offline   Reply With Quote
Old 04-16-2004, 05:46 AM   #8
Big Yellow Monkey
The XLE has the power sliding doors, and thus have a different remote...
-Biggie!
Old 05-08-2004, 02:51 PM   #9
cockeyedgull
Thanks for the instructions...but I can't get them to work. Anyone else have any luck with them?
I've got a 2001 Sienna LE.
cockeyedgull is offline   Reply With Quote
Old 05-25-2004, 02:14 AM   #10
spotco2
Banned
Try here for programming procedures for Sienna
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
spotco2 is offline   Reply With Quote
Old 06-14-2004, 08:34 PM   #11
whitcre
remotes for avalon/camry/solara same?
i just bought a 2003 avalon that doesnt have the remote. what should i look for on ebay? also, does the remote program the car or does the car program the remote - in other words, can i buy two different remotes and and have them both programmed to work on the same car
whitcre is offline   Reply With Quote
Old 12-10-2004, 08:39 PM   #12
Latif
Hi All,
I have 1998/LE Sienna that I have just purchased a remote on eBay .I need programming instructions. I have found some instructions on different Toyota models and years but they don't help me to work for 1998 Sienna. Please any one would help me? I’ll be thanking this act of kindness.
Latif
Latif is offline   Reply With Quote
Old 01-15-2005, 12:58 PM   #13
vic000
-Biggie!
I have a 1999 Sienna XLE, and the above worked for me.
I had bought a FOB on ebay months ago for about $5,
and when I went into the local dealer and he asked for
$100 or more to program it, I said forget it and put it aside.
Well, I saw Biggie's message yesterday, and gave it a shot
this morning -- actually, three shots -- and it worked!
ADVICE FROM MY EXPERIENCE: BE CONFIDENT THAT A LOT
OF INFO IN THIS FORUM (ALL FOR ME SO FAR) IS ACCURATE.
vic000 is offline   Reply With Quote
Old 01-15-2005, 01:14 PM   #14
vic000
Re: Re: Help needed in programming Keyless remote for 2002 Sienna
I forgot to mention that my XLE is without power sliding rear doors.
Old 01-15-2005, 05:09 PM   #15
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
Brian R. is offline   Reply With Quote
Dealer says new computer needed to program keyless remote, I think they are wrong.. hoover101 Sequoia 2 03-17-2010 12:17 AM
96 Camry CSI Program Keyless Remote JeanC Camry/Camry Hybrid/Vista 1 07-15-2009 01:28 PM
Programming keyless remote for 2002 Grand Prix GTP mad_max Grand Prix 4 04-15-2007 12:00 PM
Need help programming keyless remote for 99 T&C mikeDFW Caravan | Voyager 4 01-15-2005 03:33 AM
Need instructions for programming keyless remote for '94 G/Caravan Yankeedrummer Caravan | Voyager 0 08-01-2003 02:45 PM
