| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
96 Eclipse Rs 2.0 Non-turbo
Im having a problem with my car back firiring. It idles fine a 2000 rpm but at 1000 it just act funny like it wants to cut off! Now my engine light came on and its throwint a code... the coad is 1294. can some one help me! i got a new battery and it keeps going dead... then i found out that my alt was bad so i took the engine out changed the alt all belts even the timing... and its still doing the same thing. When i try to accerlerate it stutters and jumps really bad then eventually cut off... oh and i chaneg eht fuel pump and the fuel filter! Can anyone help me?
Re: 96 Eclipse Rs 2.0 Non-turbo
You pulled out the engine to replace the alternator and the timing belt? Im not really sure on the work you did? Did you change the timing belt? Did the car run fine before you did this work? Maybe the timing is off a tooth
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Na, i didnt touch the timing we just checked and made sure that it wasnt off at all! i just put a serp and alt belt on! I took the engine out of a automatic 96 eclipse and just put my tranny on it. thats all i did and idk whats causing this backfire. do you think the EGR valve would cause this? I was also looking at my car and i dont have a EGR silonoid...
EGR won't make a difference like that. I've had defective, broken, and EGR deletes on numerous cars and never had problems with backfiring. It recycles the exhaust gas back into the intake. Wouldn't cause a problem like that if it wasn't working or whatever. Quote:
Ok... now me and some friends were standing outside and we just let it run for about 30 mins and then the car caught on fire and the ground did too! so if my converer is clogged up or messed up will than make my car backfire?
