Old 10-22-2001, 02:21 PM   #1
Guiddy
Guiddy's Avatar
Heat staining exhausts!
Something all you guys need to get into! Looks great!
http://www.tamiya.com/english/howto/bike1/tip1.htm
Guiddy is offline   Reply With Quote
Old 10-22-2001, 03:25 PM   #2
JE123
JE123's Avatar
That is a great tip. How much does an airbrush cost like that one? It doesn't have to be a tamiya one.
JE123 is offline   Reply With Quote
Old 10-22-2001, 05:05 PM   #3
Guiddy
Guiddy's Avatar
If you want a topload like that one, they go for around £100 here.
I have one and love it to bits.
Really easy to clean as you harldy put any paint in it!
Old 10-22-2001, 05:14 PM   #4
JE123
JE123's Avatar
What is a good cheap one that has an adjustable nozzle. One that can spray wide and narrow for detailing.
Old 10-22-2001, 05:36 PM   #5
Guiddy
Guiddy's Avatar
the trouble with most is the fact they are suction fed, which deteriorates quickly when the seals harden, plus you need a lot of paint because the gun has to suck it up!
You can get a nice Badger one for £50 though.
http://www.badger-airbrush.com/
Old 10-22-2001, 07:22 PM   #6
MercCougarXR7
MercCougarXR7's Avatar
Go with a Badger 350 - easiest model for beginers. It has a bottle feed (from the bottom), it's easy to assemble/dissassemble, and doesn't cost too much in the first place.
As for the exhaust tip - I don't like it. Looks Very cheesy - I like my models to look like they had just rolled off the Factory floor .
2000 LS8 Sport, 1992 XR7 5.0 HO
MercCougarXR7 is offline   Reply With Quote
Old 10-22-2001, 07:39 PM   #7
Jay!
Horizontally Opposed
I concur. Though it's a good detail bit for a race car.
Hierarchy of Subaru:
(Click to see mine!)
Jay! is offline   Reply With Quote
Old 10-23-2001, 04:45 AM   #8
Guiddy
Guiddy's Avatar
I'll show you mine and let you make your own minds up!
Old 10-23-2001, 07:24 AM   #9
primera man
"P-Man"
primera man's Avatar
Re: Heat staining exhausts!
They make it look so easy. !!!
Nice tips on how to do it.
View All My Models Here.
primera man is offline   Reply With Quote
Old 10-23-2001, 08:06 AM   #10
Moppie
Master Connector
Moppie's Avatar
The problem with weathering, and I think this is the answer to a debate which is older than any one here is: Once you've whethered on part, you can't stop. Next you have to add tyre wear, scoring on the brake discs, bugs, oil stains, dirt, worn seats, etc etc.
If your going to add realism to a car, to make it look a little used, then you need to make all of it used.
But if your going for straight off the show room floor look, then you don't want to add wear any where.
If your going to Weather parts, you have to weather the whole car to keep it all in balance.
Moppie is offline   Reply With Quote
Old 10-23-2001, 07:09 PM   #11
MercCougarXR7
Yah - what he said !
What color is that on the underside of your car Guiddy? I like it - looks like a combo between Gun Metal and Steel .
Old 10-24-2001, 03:29 AM   #12
Guiddy
Guiddy's Avatar
It's Honda Silverstone Metallic, the correct S2000 colour!
Old 10-24-2001, 01:56 PM   #13
Jay!
LOL! You're not far off, Merc. To make Silverstone Metallic, you mix one part gun metal to two parts chrome silver.
Old 10-26-2001, 11:24 AM   #14
MercCougarXR7
Thanks Jay! I've only just started to mix and match paints - I have so many old paints just laying around, I may as well put two together to make a new color (notice the 3 2's ?).
I made a beautiful color from Olive drab green by adding some metalic dark blue. It now is the perfect color to put on the Japanese Army version of the Zero.
I'm definately going to make that Silverstone paint - great name for it too !
Old 10-26-2001, 12:51 PM   #15
Jay!
Here are the seven factory colors the S2000 is offered in. Silverstone Metallic is the first one.
No heat when not on throtle... COLD... rmwilson Problem Diagnosis 13 12-26-2009 02:09 PM
TIP: Smell When Run Heat on FULL... Intuit Escort 7 11-14-2009 05:11 AM
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 09:49 AM
Heat shielding/ Exhaust wrap ZilverZilvia 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 7 02-13-2006 07:28 PM
sr5 heat shield/exhaust preta Corolla/Matrix/Voltz 1 07-18-2004 04:43 AM
