Go Back   Automotive Forums .com Car Chat > Volkswagen > Passat
Old 06-20-2004, 05:27 PM   #1
hermbo
Help My Brake Lights Won't Go Out!
I have a 2003 Passat and discovered this afternoon that my brake lights won't go out. I'm going to take it to the dealer in the morning but would like to disable the lights tonight for obvious reasons. I can't figure out which fuse works or how else to do it. Any advice?
Thanks
hermbo is offline   Reply With Quote
Old 01-27-2005, 09:10 AM   #2
jhempstead
Brake lights stuck on
I too havea 2003 Passat and my brake lights are stuck on in my parking garage at work. What ended up being the problem? Did you find out how to "override" the switch? I'm waiting for a call back from the VW dealer, but these guys can take hours.
jhempstead is offline   Reply With Quote
Old 01-29-2005, 01:17 AM   #3
veedubmechanic
VDUBMAN
veedubmechanic's Avatar
Brake light switch.
2003 is covered by warranty.
veedubmechanic is offline   Reply With Quote
Old 11-02-2005, 09:44 PM   #4
kschulz
Had the same problem tonight, also a 2003 Passat. After messing around with it for an hour, I finally reached *way* up to the top of the brake pedal (out of sight, behind the panel) and found what felt like a connector to the brake light switch. Pressing on the connector made the brake lights go out. I can sleep now. Off to the dealer tomorrow...
kschulz is offline   Reply With Quote
Old 11-03-2005, 09:44 AM   #5
jhempstead
Re: Help My Brake Lights Won't Go Out!
Good to know. I'll go exploring under the brake pedal for that connector to be prepared for next time.
Old 06-27-2008, 10:02 AM   #6
luqman76
Having same problem, temporary solution is to remove fuse number 5, had the brake light switch replaced twice, still no good, NEED HELP.
luqman76 is offline   Reply With Quote
