Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 11-27-2001, 07:04 PM
nwong nwong is offline
Chassis Format?
Ok ... so I've decided to get a G20 and I want to put a DET in it ... however I'm having trouble deciding on which platform ... P10 or P11? Any difference? Engine doesn't matter because I'm putting the DET in, but are there any other considerations I'm overlooking? Body can be redone with the right body kit. Lights? Cosmetics? Anything? Thanks!
Old 11-27-2001, 07:32 PM
APEXSER APEXSER is offline
OBD I & OBD II
The 91-93 P10 would probably be the easiest platform to swap a DET into only because of its similar wiring harness and lack of OBD II. The 94-96 P10 will work, but you will have to deal with the difference in harnesses and the OBD II. JWT can reprogram the ECU to eliminate the 2nd O2 and the EGR System. The 99-00 P11 will be a little harder swap, since yo will not only have to worry about OBD II, 2nd O2, and EGR system, but you will also have to worry about repinning the Harness into the ecu to use a 94-96 P10 ECU, since JWT cannot reprogram the P11 ECU! I hope this helps!
Louis Anaya
1992 Nissan Sentra SE-R Turbo
12.0 @ 118.77 mph
349.6 HP & 301.9 FT/LB
SR20 Performance
www.sr20performance.com
480-966-SR20
480-966-0100 Fax
Old 11-27-2001, 07:52 PM
Are there anything else to consider? Suspension? Parts? Modifiability?
Old 11-27-2001, 07:53 PM
G22DET's Avatar
G22DET G22DET is offline
Send a message via ICQ to G22DET Send a message via AIM to G22DET
or you can just buy my car..saves you lots of trouble on how to make your car nice. here's the link to pics of my car...
http://www.automotiveforums.com/vbulletin/t8478-1.html
Luke C.
GDA Power!
Old 11-27-2001, 10:00 PM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Yeah aside from buying Lukes car I'll have to agree with APEXSER.
Old 11-28-2001, 03:59 PM
T4 Primera T4 Primera is offline
P10 should be cheaper of course and you'd be able to adjust rear toe (independant rear) which isn't easily done on a P11 (muti-link beam).
If you're going to lower the car, we can get front adjustable camber correction kits and caster adjustment kits, for both platforms, in New Zealand that you may not be able to get in The States.
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Mounting body over a spaceframe chassis ? engineblock Engineering/ Technical 3 09-26-2010 10:11 PM
Formatting AEstud COMPLETELY off-topic 13 03-08-2002 01:55 PM
Who likes the new format better!! super 96 accord General Discussion 3 11-14-2001 02:38 PM
New Format johnny Road & Track 1 05-15-2001 03:32 PM
