Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 04-09-2003, 06:36 PM
inchhighpihumphrey inchhighpihumphrey is offline
Pathfinder Keyless Entry
I bought a 1995 Nissan Pathfinder and I am wondering if anyone knows how to tell if it has keyless entry?
Thanks,
Craig
Old 04-10-2003, 08:55 PM
Nissan Sales 310's Avatar
Nissan Sales 310 Nissan Sales 310 is offline
Send a message via AIM to Nissan Sales 310
You can do yourself. It's not too tough as long as you're using the correct remote. Get in the vehicle. Close and lock all doors utilizing the driver's power-door lock/unlock switch. Insert and remove the ignition key more than six times within a 10-second period (at a rate of one insertion/removal cycle per second). Don't rush the process, and be sure the key is completely withdrawn from the ignition-key cylinder each time it's removed. Turn the ignition to the ACC position and press any button on the remote one time. The hazard lights should flash twice, letting you know your mission is a success. If you were going to program more than one remote, you'd simply unlock and lock the doors once again with the driver's switch and press the one button, one time, on the second remote. The procedure is completed by turning the ignition off, unlocking with the driver's switch, and opening the driver's door.
Robert
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 05:46 AM
remote keyless entry problem smity9089 Intrigue 0 04-14-2009 12:45 AM
1999.5 Pathfinder Keyless entry programming questions mikehoncho87 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 06-23-2007 10:40 PM
93 Pathfinder Keyless Entry Programing Info K_Jonesie Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 4 01-09-2004 02:14 PM
95 pathfinder keyless entry tenseed Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 2 10-05-2003 02:42 PM
