Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > C/K
Old 12-29-2002, 02:36 PM   #1
krazma
Remove Driver Door Panel for 1998 LS
Can someone tell me how to remove the driver side door panel? The inside door latch broke and I would like to replace it myself.
Thanks.
krazma is offline   Reply With Quote
Old 01-07-2003, 05:58 PM   #2
Shortbus
Blah blah blah
Send a message via AIM to Shortbus
There is a tool available you can find them at checkers, pepboys ect..
It looks like a flat for with the middle teeth missing. The door panel is held on by two piece plastic retainers(plan on replacing at least half of them they are easy to break) Just be patient and start at a corner of the door panel and pry it off being carefule not to pull to hard and crack the panel itself. once you have the panel loose you will have to pull upward on it to unseat the inner belt molding. Just go back on with it in reverse order. Good luck.
Shortbus is offline   Reply With Quote
how do I remove drivers door panel shirley6don LeSabre 0 09-08-2009 07:35 PM
How To: Remove Door Panel LifeIsPain Montana/Montana SV6 1 03-21-2009 08:08 PM
2003 GTS How do I remove driver door panel? nativtxn53 Eclipse 2000+ 1 02-12-2009 08:17 PM
Remove Driver Door Panel - 2000 Navigator johnmsch Navigator 1 12-03-2008 06:25 AM
Removing drivers door panel on 90'Century NATE7 Century 3 09-04-2005 12:58 PM
