Old 11-27-2002, 10:46 AM   #1
civicHatch
Send a message via AIM to civicHatch
B18B or B18A
hello,
I have a 88 civic hatch dx and am planning to swap either a b18a from a 90-93 integra or a b18b from a 94-00. My question is what is the difference between the engine and which would be easier to swap in. Also, I am planning to get the place racing mounts, with these mounts, will the engine fit in the bay without any cutting or welding. Any help would be apreciated.
civicHatch is offline   Reply With Quote
Old 11-27-2002, 08:19 PM   #2
MyFirst4G
MyFirst4G's Avatar
Send a message via AIM to MyFirst4G
Okay first off, the b18a from the 90-91 model teg has 130 hp and the 92-93 had 140 like the b18b from 94-01. Now i also have a fourth gen and first thing you will have to do is change over from Dual Point Fuel Injection to Multi Point Fuel Injection, check out www.4thgenerationcivic.com for that info in the HOW-TO section. After you get the mounts, another problem lies ahead, the tranny, you will have to use a Cable tranny UNLESS you have madd $$ and can do a Cable to Hydro tranny conversion. The 90-93 tegs have cable and 94-01 have Hydro. So you can use a 90-93 tranny and a 94-01 engine, but it's best and probably cheaper to get it from the same car, so get the engine from a 92 or 93 teg cause it has 140 hp...... Now you will also have to get shift linkage because out linkage is too long, so you can get it from HaSport or get the teg linkage and shorten it about two inches and weld it back together. Personally for like another 300 or so you can get a b16a with a cable tranny, and if your inluck, it might have LSD.... Hope this helps!!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
MyFirst4G is offline   Reply With Quote
b18b intake manifold on a b18a Sid77 Integra 1 10-28-2003 12:15 AM
Swapping B18a head toa b18b moleodonuts Integra 2 10-27-2003 07:01 AM
will a b18a head interchange w/ b18b? hondacivicjunkie Engineering/Technical 2 08-13-2003 09:34 PM
b18a and b18b whats the difference really need to know!! funkdaflex1 Engineering/Technical 14 06-24-2003 05:53 AM
B18b, B18a mr_x_89 Engineering/Technical 1 09-10-2002 03:43 AM
