Old 11-19-2002, 01:10 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Igniter unit HELP!
Hey, I think I finally figured out what is wrong with my damn car. I think the igniter unit is fried (or possibly the ignition coil). Anyways, I plan to replace the ignition coil first, and if that doesn't work, I'm gonna try and replace the igniter unit.
Can I do that, or do I need to buy a whole new dizzy?
Old 11-19-2002, 01:48 AM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
its easy, just pop off the cap, and bam the coil is right there, there are two wires connected to it.....easy replacement. The ignitor is slighty harder but not really, its under the coil, has like 5 wires connected to it and 2 bolts holding it on. Its like a 10 minute job to get them replaced.
Make sure you mark which wires go where.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 11-19-2002, 01:57 AM
91civicDXdude's Avatar
91civicDXdude 91civicDXdude is offline
Send a message via MSN to 91civicDXdude
I have been told numerous times and saw it proved numerous times.
on a honda, IT IS ALWAYS THE COIL.
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
Old 11-19-2002, 02:37 AM
Not 100% true. The RECALL on early 90s honda civics was based on the ignitor.
I had my ignitor go out on my car when i was driving down the road.
But best way and cheapest method, is to first replace the coil, then the ignitor.
-2000 Civic Hatch
-1998 Lexus SC300
Old 11-19-2002, 12:49 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
You could say the hell with this and swap that d16y8 in there right now, but you are probably still working on it.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 11-19-2002, 01:26 PM
ci5ic's Avatar
Yep, still got about 4 grand I need to spend on it before it's ready (turbo w/intercooler, lightweight pulley's, timing gear, flywheel, etc.)
Thanks for the help y'all. I'm gonna go outside and test my coil right now. Just gonna throw the ol' volt/ohm meter on there and see what I get. If it checks out, I'm gonna try and find myself a new igniter somewhere...
It's about funkin' time, though. I've been without my car for almost 2 months! And to top it off, my Jeep is fucked too!
Old 11-19-2002, 01:51 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
whats wrong with it?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 11-19-2002, 02:32 PM
Melt's Avatar
'Cherokee4.0HO' messed with it cause it was coller than his :hehe:
Remember that idiot?
AF Bay Area Crew
Old 11-19-2002, 03:10 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Ingnitor
I hear of these often going....a matter of fact i have an extra one i'll sell to anyone if they want it and i also have and extra coil...both work great.
Old 11-19-2002, 06:53 PM
ci5ic's Avatar
Re: Ingnitor
Dude!!!! I would like to get my hands on your ignitor if it's not too spendy. I still don't know for sure if the ignitor is the problem.
I replaced the coil today, and no improvement, so that is not the problem, going to return the coil for a refund ($84 for a fuckin' coil?!), so I removed the ignitor, but don't see any physical signs of damage, but I want to replace it and see what happens. There's nothing in the helms manual that says how to test it, so I'm just gonna stick a new one in.
I really hope I don't have to buy a whole new dizzy for this engine, when I'm gonna have to turn around and buy another one for my D16Y8 in the next few months...
Okay, now this is some bullshit... ALL I DID WAS A FUCKING TUNE-UP! I replaced the air-filter, spark plugs, plug wires, and cap/rotor. Now, it runs like total ass, like it's missing, or like it's running too rich or like the timing is way off.
FAQ:
1.) YES, I gapped all the plugs properly (actually, they were all pre-gapped, but I checked them with the guage anyways).
2.) YES, I'm absolutely POSITIVE that I have the right firing order.
3.) YES, I'm sure all the plug wires are on the right posts.
4.) NO, I did not accidentally bump the distributor, thus affecting the timing (The timing is FULLY controlled by a computer, and the dizzy does NOT rotate, and there is NO way to manually adjust the timing).
5.) YES, all the plug wires are good! They all get spark, and I have personally been shocked by each one of those motherfuckers.
6.) YES, the coil is good.
7.) NO, I didn't fuck with anything else.
I've already posted this in the Jeep Cherokee forum, but if y'all have any ideas, I'd love to hear them (although I wouldn't be surprised if I've already heard them)
Old 11-20-2002, 03:12 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
are u sure that all the wires are plugging into the plugs?
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 11-20-2002, 04:48 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
well if you put the rotor on good, double check, and the cap on good, double check. then either you must have messed up the wiring, or you didnt put the spark plug wires on the spark plug good.
one time i was working on this Z28, doing a full tune up. so i replaced the rotor, cap, wires, plugs. well as you know, when you put the wire on the plug it suppose to click on, and that tells you its on good. well i clicked all of them on but one, so i started it up and drove around and it was missing. so i just switch wire spots and i got it clicked on, and it ran fine, plus after the tune up, the car felt more responsive and faster.
point is make sure you put the wires on the plugs good, you can tell that by a loud click it makes when it snaps on the plug, not a soft click but a loud click. because i noticed that it has a small click once then a loud click after when its on good
2000 IG ignition fuse blowing...Please help!!! stanley24538 Metro 5 04-24-2010 10:18 PM
Not Starting, did ignition switch - no help Royalwapiti Intrigue 10 02-10-2010 02:37 PM
1973 el camino- electronic ignition. HELP Landmeier El Camino 3 04-14-2009 09:33 PM
helpppppp no spark,how to remove igniter unit jtchevy355 Accord/TSX/Accord Hybrid 7 09-07-2005 09:42 PM
msd ignition unit with turbo bluecivicdohc Forced Induction 4 01-10-2002 10:23 AM
