Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Suspension and Drivetrain
Suspension and Drivetrain Discuss suspension, and drivetrain performance modifications here.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 05-03-2002, 12:30 PM
skidmark skidmark is offline
Gears?
Can someone please explain. If your gears are higher, what happens? If your gears are lower what happens? thanks everybody.
:badass: check out www.gm-cars.com its just gettin goin, and is a pretty cool site.
Old 05-03-2002, 05:01 PM
BlkCamaroSS's Avatar
BlkCamaroSS BlkCamaroSS is offline
Send a message via AIM to BlkCamaroSS
I believe it's the higher the gears, the better the acceleration, and less streetability. 4.10's are good for dragging down the quarter mile, but are not suited for stop and go traffic. If you're looking for a good compromise between stock 3.23's and 4.10's, 3.73's are a good way to go. Depends on your car's use...
(note: I believe this is how it goes, I'm going on what I think I remember, if I'm wrong, chime in)
2001 Camaro SS #2239 of 6332
1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276
307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque
Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension
Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC
Old 05-07-2002, 08:18 PM
Blackbird01 Blackbird01 is offline
The 'gears' you're referring to are located in the rear differential.
If you lower the gear numerically, you increase the overall size of the gear. In example a 2.73 gear is smaller numerically then a 4.10, but bigger in physical SIZE.
The smaller the gear is NUMERICALLY, the higher your theoretical topspeed is but slower your acceleration is. It's just the opposite for a bigger numerically, gear.
Most LS1 6-speed owners chose 4.10 gears. I've been in a 6spd. LS1 eqpt. with them and around town it's perfectly fine. In fact, better then the stock 3.42's. On the highway, revs are kept very low with the 6th gear. From a stop, the car pulls like a MADMAN!
Most LS1 A4 owners swap to 3.73s or stick with the "optional" 3.23s that come factory. I've still got the 3.23's in my car, but I'm sure I'll throw a 3.73 out back when I get a new rearend. The stocker's on borrowed time. (knock on wood)
2001 Trans Am WS6 (A4)
Old 10-08-2007, 04:29 PM
jester151315 jester151315 is offline
Re: Gears?
to add more....fuel economy = 3.23 big burn out = 4.56........you looking for economy or show, its up to you and only you........
reason for this simply.....your engine revs higher.....
ex. 2000RPM with 3.23 at 60MPH
3200RPM with 4.10 at 60MPH
Old 10-08-2007, 05:40 PM
izzydjinn's Avatar
izzydjinn izzydjinn is offline
Re: Gears?
using skidmarks thread, if you have a v6 3.8 manual whats the best way to go.
Is.... peanut butter jelly time, peanut butter jelly time, peanut butter jelly time, peanut butter jelly time.
Old 10-08-2007, 08:16 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: Gears?
OLD THREAD!! jester, please check the dates of threads before you post in them, this one is over 5 years old!
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
4th gear vs 5th gear 92 vx Nchakos '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 12-07-2003 01:53 AM
BBC Top Gear, Fifth Gear BigDanTheMan Mustang Talk 1 11-06-2003 07:50 AM
Top Gear or was it 5th Gear? Pringles Clio/Clio II/Clio III 2 09-14-2003 03:05 AM
Zonda Roadster on 5th Gear (Part of Top Gear Family) TheWretchedBeaver Zonda 1 06-10-2003 05:12 PM
switching out my S1 5th gear to an LS 5th gear... ? CRX586 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 04-17-2003 01:03 AM
Closed Thread
