Old 10-23-2006, 10:13 PM   #1
FLCLTaro
Different lean on a 16v scirocco
I just got myself a 88 16v scirocco. The suspention consists of H&R progressive lowering springs (black sport) which lower the car about 1.5 inches. It also has BOGE strut inserts, (which I think are about stock strength). The aftermarket rims extend just past the fender of the car. The springs are less than a year old but strut inserts are probly atleast a couple years old. When I push it through a hard left it corners buetifully, but when I take it through a right turn hard enough I can get the front drivers side tire to rub against its fender. Ive been told by many people that this is probly because of the spring. But they seem to new to be bad already, could it maby be something else? Everyones opinion is absolutly welcome. Thanks.
FLCLTaro is offline   Reply With Quote
Old 10-23-2006, 11:23 PM   #2
TheSilentChamber
Forunn Daberator
TheSilentChamber's Avatar
Re: Different lean on a 16v scirocco
lowered car with wide rims... tires rubbing.... is this really a question?
TheSilentChamber is offline   Reply With Quote
Old 10-24-2006, 10:41 PM   #3
curtis73
Professional Ninja Killer
curtis73's Avatar
More likely, its production tolerance. There are many reasons why, but a good measurement of the clearance to the fender is in order. On my 96 Impala SS, the rear axle is shifted to the right by a complete 1.5". I don't have rubbing since its the rear axle, but if I want that sexy 315mm rubber I'll have to run a different offset on the left and right.
Its also possible that the fender was dented and repaired with a slightly different contour, or that the alignment is different on the right than the left. Often times alignment shops will put different camber on each side to help correct for crowned roads. Its also possible that caster is affecting the steering and camber gains in the turn.
Big wheels and big rubber mean big measuring. I'm sure its not the spring. Even if it endured 50 years of sagging, the spring may have a different installed height, but not a different rate.
There are a thousand reasons why one side could rub and the other be fine, but I'm sure the spring is not one of them.
Dragging people kicking and screaming into the enlightenment.
curtis73 is offline   Reply With Quote
Old 10-24-2006, 10:43 PM   #4
curtis73
curtis73's Avatar
The other consideration is that your springs are probably in the neighborhood of 500 lb per inch rate. When you put your butt in the driver's seat, that accounts for 3/8" right there. Then you get your weight slinging around a turn at .5g and your 187 lbs is suddenly 374. That's a lot of weight transfer for a car that only weighs 2400 lbs.
Old 10-24-2006, 10:45 PM   #5
2.2 Straight six
That thing got a Hemi?
2.2 Straight six's Avatar
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
could it also be the side-to-side weight balance? lowered car, if there's more weight on one side, it's more likely to rub.
Seatbelts Saved My Life
2.2 Straight six is offline   Reply With Quote
Old 10-27-2006, 01:10 AM   #6
FLCLTaro
Talking Re: Different lean on a 16v scirocco
Hey, thanks a lot for you extensive replies. It mostly helps to know that its not the spring thats the problem. Also I never really considered the amount that my wieght would effect the car's weight balance. Though its probly that and a combination of something else. Either way thanks again.
