Go Back   Automotive Forums .com Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 05-30-2002, 01:45 PM   #1
raja
Cool where exactly are Boost sensor and Evap. canister control valve?
Can any body tell me where exactly are Boost sensor and Evap. Canister Control Valve and how can replace them?
Thanks:frog:
raja is offline   Reply With Quote
Old 05-30-2002, 01:47 PM   #2
raja
Sorry it is for 1996 Maxima. Thanks
Old 05-31-2002, 12:33 AM   #3
mtrai760
Send a message via AIM to mtrai760
Why do you want to replace them? The boost sensor is on your intake piping, and the evap is a black plastic thing on top of your intake manifold I think.
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
A hunting we will go...
mtrai760 is offline   Reply With Quote
Old 06-24-2002, 08:06 PM   #4
ZSlice32
Possible Locations
My "Boost Sensor" is giving me hell and I'm looking to replace mine too. This layout is pretty generic, but may be off for your vehicle. The "Boost Sensor" that you speak of is probably the EVAP Pressure Sensor. It should have three wires or plugs (Red, White, Green if I remember right) and a single plasic nipple for a vacuum/pressure hose, about a quater inch in diameter. Now to confirm that your pressure sensor is too blame for any problems, your "Service Light" may have come on. The code that most closely relates to this sensor failing is P0450, retrievable by putting the ECM into diagnostic mode, or scanning from a local auto shop (I hear that autozone will do it for you now).
The EVAP canister is generally located under the car behind the rear left wheel, sometimes it is on the left. There are several sensors and solenoids associated with the EVAP system. In my case, there are 5.
Since this part is part of the Auxilary Emissions control, it is under a warranty by law. If any part involved with emissions fails in the first 50,000 miles of a vehicles operation it is the manufactuers responsibility to replace that part. I'm not sure if the age of the vehicle matters.
To replace the sensor, or any part of the EVAP system, you will need to relieve pressure in the system. This can be done by opening the gas cap, or using the Schrader valve in the engine compartment marked EVAP service port. Once pressure is relieved you should be able to swap the components. In my experience, under chassis machine screws tend to break easily, so it might be handy to have another way to secure the parts.
(In case you're wondering, I have a second generation Altima, although I believe the chassis is first gen.)
Hope that helps.
ZSlice32 is offline   Reply With Quote
Old 07-01-2002, 03:31 PM   #5
raja
Thanks for your post. It was a big help.
EVAP Canister Issues/Possible bypass? sk8injon Engine and Transmission 1 07-25-2009 09:39 AM
code: 1655 EVAP canister purge valve luvmyS10 Beretta 7 01-21-2009 04:11 PM
Can't find EVAP Canister Vent Valve ('98) jkwiechert Prism 1 06-16-2008 02:51 AM
Replacing Evap. canister Control Valve, Boost Sensor, and Knock Sensor? raja Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 16 06-04-2007 04:25 AM
Where are the EGR and Idle Air Controller Valves located? ninpo23 Rodeo | Passport | MU 4 05-18-2006 01:36 AM
