lowering springs question
will just using a set of aftermarket lowering springs (no shocks, no coilovers, jus springs) damage anything on a stock suspension?
It's very possible you will blow the stock shocks, especially if the springs drop the car quite a bit and/or are much stiffer than stock.
'03 Corvette Z06 '99 Prelude SH |
yep. Definately will have to get some sport shocks from koni or bilstein. Those will run you about 300 bucks.
"Wheel spin in 2nd! 3rd! 4th! OHH!!!" -Tiff Needles driving the Mclaren F1 |
and dont go to low.. or youll really need camber kits to help out..
Racing Rice Cars: '97 Civic EX, '02 Explorer Eddie Bauer, '99 Isuzu Amigo 4x4 Bikes: '05 Suzuki DL650 Vstrom, '05 Yamaha Raptor 660R |
me = newbie
what are camber kits? what do they do? and how would it help if you go really low on the car?
cambers help with the alignment of your car
the stock cambers dont have enough adjustability to align the wheels when you car is lowered, so you would have to buy aftermarket camber kits to allow you to have proper alignment |
seriburi...
CAMBER:
Camber is the angle the wheel deviates from perfectly vertical when looked at from straight ahead. Positive camber would have the top of the wheel inclined outwards, away from vehicle center, while negative camber has the top of the wheel leaning inwards to vehicle center. Contrary to popular belief, any and all camber angles hurt tire adhesion to the road, and for one obvious reason. Tires create the most grip when they put the biggest footprint onto the pavement possible, and any significant camber angles shrink the all important contact patch. The reason people associate negative cmaber with good handling is because as body roll occurs in a corner, positive camber is naturally imparted to the outside wheels. The suspension's camber angle at static ride height (plus it's camber curve, see below) will determine whether the wheel goes into positive camber during body roll, or simply balances out to zero camber. So just know that ideally we want zero camber at all times, but like most things automotive a compromise must be struck: dial in a bit of negative camber at static ride height for the least amount of positive camber possible at maximum effort cornering. As you lower a Honda more and more, negative camber becomes an increasing problem. Bad tire wear, poor handling and directional stability can all be side effects of too much negative camber. Honda suspensions also have very limited (if any) camber adjustment, so buying a camber kit is basicaly just buying a greater level of adjustment so you can get the alignment specs correct.
how low can you drop a civic without having to use a camber kit
The general consensus is about 1.5" before you start running into problems. 1.7" and you'll probably be alright (it depends upon your specific tire sidewall), 2" and you'll definitely be seeing camber issues.
Re: seriburi...
Mods: AEM intake, DC Sports 4-1 header, Tanabe exhaust w/ 2.5" custom piping, ITR exhaust cam, APEXi VAFC, AEM FPR, Warlboro 255l fp, RC 440 injectors, ACT stage 3 clutch, JR Supercharger, Weapon R coilovers, VIS CF vader hood, CF Angel Eye Projector headlights, Black housing corners w/ amber bulbs, "Hybrid" rear emblem, custom rear speaker panels. |
Oh, and the ride is almost like stock.
---------------------LX98Civic ---------------- nemesls_2000 ------- civickid77---------------- --- --- --- -- Sleeper in the middle -- --- --- ---
Re: Re: seriburi...
what does it look like when tires cup?
WOW! Talking about revising an old thread
Have nothing better to do?http://www.kaltire.com/commercial/me...es/cupping.php
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!Autocross Help Page Buy my Civic parts! |
