Old 05-19-2002, 06:44 PM
patate's Avatar
patate patate is offline
: ( changing rims
I have see the site of mentel but it lack of explanation on how to change rims and colors(or I just dont understand)
Old 05-19-2002, 07:16 PM
mentel's Avatar
mentel mentel is offline
Racing Forum Moderator
Send a message via ICQ to mentel Send a message via AIM to mentel Send a message via MSN to mentel Send a message via Yahoo to mentel
okay what you do is this.
1. find picture of a rim that is at the same angle as the picture your putting them on.
2. using the Polygonal Lasso tool (it's in the top left part of the tool bar, it's 2nd one on the left from the top) cut around the rim, press CRTL+C to copy the rim , and then go to ur picture and press CRTL+V to paste it on there.
3. Place the rim right overtop your picture'. press CRTL+T to free transform it. Zoom in a bit to get a better look at it , then right click on the rim that u cut out and select "DISTORT".
4. Pull the rim to the shape you want it. match it to the rims size on the picture.
5. once your done re-sizing the rim, hit ENTEr to get out of free transform and take a look at your picture.
there, hope th is helps you!!
now all that's left is the back wheel, try it out!.........
Try taking the front wheel off that picture above , and putting it on the back wheel!........good luck!
-mentel
Old 05-19-2002, 07:23 PM
sarujin's Avatar
sarujin sarujin is offline
The easiest way i can tell you to change rims is this.
Find the photo you want to TAKE the rims from, select the rims. Use the polygon lasso tool, (if you need help, use help and search select).
Once you have selected the rims, go edit,copy.
Now go too the photo you want to put them on, and go edit, paste.
They will probably be the wrong size or look wrong. So go edit, transform. Use all the different kinds of transforming to get them to look right.
sarujin
Real Car: 1990 Honda Civic Hatch
R/C Cars: M-01, M-03, Pro3 & Xpress
Old 05-19-2002, 09:31 PM
intgra22 intgra22 is offline
Banned
dont use distort use free transform...make it the right size....then rotate it for the right angle.
Old 05-19-2002, 10:17 PM
mentel's Avatar
hey intgra, how about let him use whatever he's most comfortable with.........they both perform the same task
Old 05-19-2002, 10:48 PM
sarujin's Avatar
Hey mentel, intgra22 was just giving him another way of doing something, why take offence?
Hell you were telling him to use distort, not anything else.
sarujin
Old 05-22-2002, 08:50 PM
patate's Avatar
I have found how to do it
How can i change rims on to a maisto car? bullitt smoke Diecast Car Modeling 1 07-31-2006 02:31 PM
How to change rims? asaenz Gran Turismo Series 8 03-15-2005 02:07 PM
Changing Rims and Tires 2x2 Tacoma Civerson Tacoma 3 09-09-2004 11:54 PM
thinking about changing rims... kentchoi SC300/SC400/SC430/Soarer 9 08-04-2004 09:28 AM
Changing Rim Size - Problems? Madigon Mustang Talk 2 07-09-2003 06:42 PM
