disable DRL
does anyone know how to disable day time running lights on a 98 camaro? i've tried a few things but everything seems to always undo two things i have done before....any help at all would be greatly appreciated!
Re: disable DRL
why would you want to? and do the 98's have a dome override button?
![]() 1995 Camaro - Z28 - M6 - Hardtop 2007 GMC Sierra 2500HD SLT Classic -R.I.P. Andy (Hypsi)- |
Re: disable DRL
what have you done?
Re: disable DRL
i had a 99 blazer that I disabled the DRL's by pulling a fuse under the hood, and in my 98 Aurora they're disabled by unplugging a harness under the hood on the left fenderwall, and on my buddy's 98 Grand Prix, they're disabled by pulling a fuse from the interior fuse panel.
Re: Re: disable DRL
Re: Re: disable DRL
i looked in the owners manual and pulled every fuse that had to do with the DRL's except the ones that controlled the gauges too and it still didnt disable the DRL's....i really appreciate your guys help! any more ideas?
Maybe take out the bulb? Because I know that the daytime running lights on my Monte atleast is on a different bulb than the regular lights which I use at night.
Re: disable DRL
Well sucks for you because my turn signals are on a different bulb too.
![]() Have you tried to take away the relay? Because if I remember correctly there's a DRL relay or so.. keep looking around and do a search on google.
i had looked on google before and had mentioned it in my other post a couple weeks ago, i have found a few ways but when i try one thing it keeps undoing what i had done before.....lucky bastard...i'd give anything to have the separate lights!!!! thanks again for your help! i'll look up the relay for it because honestly i dont know!
Re: disable DRL
how did you disable the automatic lights?
Re: Re: disable DRL
Re: disable DRL
ok, i just read the other thread on how you disabled the automatic lights, did you use just a plain wire or a resistor? on my 99 Blazer I had to put a 1.5ohm resistor in the sensor harness.
i just used a plain wire and it works fine disabling the automatic headlights...just the problem im having is that when i re wired the fog lights to stay on with the high beams it turned my drl's and automatic headlights back on, i have the automatic headlights fixed...now if i could only get rid of those damn drl's lol...im sorry i know this is horribly confusing without actually being here and seeing it first hand lol, thanks for your help!
