Old 07-08-2003, 12:50 AM
jdfson jdfson is offline
Question 4L80 transmission woe's
I have a 2000 Chevrolet K 2500 Crew cab with a 7.4 Liter engine. 4x4 and 4L80 transmission. The transmission works well in most cases except when it downshifts by itself. It wont shift back into 4th / overdrive and it will shift hard untill the truck is shut off. This is an old body style truck with 80k. If I kick it down into passing gear, It will shift normally back into overdrive and function correctly. It was showing an internal slippage code (18 something or other) and I replaced the shift solinoids and Tq. conv. solinoid. It helped some but it's gone back to acting up. I am thinking about rebuilding the valve body only because the tranny shifts normally otherwise. any other sugestions would be helpful Thanks.
Old 07-10-2003, 08:59 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
The most likely cause of this condition may be a loss of power to the transmission . This loss of power may be caused by an open in the ignition switch. This condition may also be the result of an incorrect installation of an aftermarket electronic device such as a remote starter or alarm system.
Just a guess!!!
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
1995 4L80 no first gear when hot jems15 Commercial Trucks 1 07-11-2010 08:48 PM
Mustang Transmission part 2001 lawg8r Mustang Problem Diagnosis 1 04-13-2009 05:24 PM
Changing Transmission mkcody88 Accord/TSX/Accord Hybrid 2 04-05-2009 02:50 PM
Transmission woes 99 in 09 Taurus | Taurus Wagon 1 02-19-2009 05:16 PM
