Go Back   Automotive Forums .com Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 11-25-2002, 06:22 AM   #1
emnm
Send a message via AIM to emnm Send a message via Yahoo to emnm
Need some help ... about SKYLINE ENGINE ... !!!
Ok here is my problem ... ???
I want to have the body of a 300zx and the Power Plant of a Skyline ... ???
I am Curently in the process of buying an RB26DETT ... it is the full engine ... untill recently i was too cought up with getting a good engine and not all the parts that are needed ... !!!
Now I found the Engine it will cost me
$ 3,800 US
(Near mint condition)
(Not a single oil leak and so on ... )
(Includes the Transmission)
Ok ... I have a 1992 300zx ... If i was to rip out the VG30DE and have a RB26DETT installed would i need to use the computer of a Skyline or use the 300zx one ...
<THINKING>
RB26DETT = SKYLINE
... so ...
SKYLINE ENGINE = SKYLINE COMPUTER
... so ...
SKYLINE ... Digital Display ...
300ZX ... Not Digital Display ... ???
... so ...
<CONFUSED>
... what do i do ...
As well as ... would i be able to get the AWD power of the Skyline in the 300Z ... ???
i know i know mst of you are thinking ... if you want that then just go get a Skyline ... ... not that i would mind .... but when i go to the car next car show ... i want me a specific TROPHY ... !!!
And by the way ...
[SKYLINE = $ 95,000 [HERE]]
300ZX = $ 3,000 to 8,000
RB26DETT = $ 3,500
[Hybrid 300ZX = $ 6,500 to 11,500 ]
Owning One of either........................ = Priceless ... ... !!!
... I greatly appreciate the help ... i just want to be able to take on any one around my neghbour hood ... and get it all without sponsorships ... so i can claim it to be my pride and glory ... Thanx in advance for all the help ...
emnm is offline   Reply With Quote
Old 11-26-2002, 12:25 PM   #2
SkylineUSA
SkylineUSA's Avatar
Send a message via AIM to SkylineUSA
I am not trying to rain on your parade, but it is going to cost a lot to do what you want.
Yes, you will need the GTR wiring harness, ECU, and Dash instruments.
Skyline digtal display, I am lost on that one.
AWD, probably not. That would be too much work.
There is one guy that has done the mod in a 240z(I think) he is sometimes on at www.freshalloy.com
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
SkylineUSA is offline   Reply With Quote
Old 11-26-2002, 06:47 PM   #3
emnm
I need a lot of $$$ ... ???
:bandit: OK ... and ... $$$ is not an option ... i want power and i want to go 200MPH ... once i hit that i will live happy ... ...
I only want the car for under R34 SKYLINE price .... that is all ... i have 300z and i found the RB26 for my car ... while i am at it screw the ECU ... I'll look for a STANDALONE SYSTEM that will replace it ... allthough it would be sooooooooooo cool to have the skyline digital display ... Ohhhhhhhh well ... allthough i am a genious when it comes to wires ... he he he ... :silly2:
I connected a computer flat screen in my brothers car ... to his dvd player ... it is soooooooo much better than the 7.5inch screens they sell for soooooooo munch ..... !!!
I wonder if i could find a way to put a flat screen display instead of the gauges ... ??? that would look soooooooo cool ... I'll look into it ...
I'll upload a pic of the engine latter ... when i find the PIC
AND 1 MORE TIME .... I KNOW IT WILL COST A LOT TO HAVE THE ENGINE IN THERE ...
The engine i found for 3,500 has rb26dett ... the stock turbos are on it ... has the transmission .. harnes ... the engine basicly needs only to be put into the car and connected to ECU, Headers, and Driveshaft ... so the thing is complete as is ... !!!
Old 12-20-2002, 05:50 AM   #4
racingbreed20
racingbreed20's Avatar
A few things I've seen done here....RB26DETT have been put in a few cars 240ZX, GTS-Ts, CEFIROs..and a few others. Or check out....... This guy Mat who works at Motorworx. Go to (http://www.motorworx.tv/) They give a little break down on engine rebuilds blah blah. Basically if you want you can get a gts-t from Mortorex(different) for about 18grand and throw the RB26DETT into it. The mounts shouldnt be a problem just need the ECU/ harness stuff. And I almost wanna say you can fit it to a RB25DET Tranny. Dont quote me its just what I've heard. Of course I can get you some more names of some guys who stuck with a VG30DETT and are doing just fine. 300ZXs Are too heavy for me.
racingbreed20 is offline   Reply With Quote
Old 12-20-2002, 07:47 AM   #5
RazorGTR
Skyline Man
RazorGTR's Avatar
The biggest concern I can see is the length of the RB motor into that shallow but wide engine bay of a 300ZX.
Next would be the mounting of the motor and gearbox. The GTR gearbox is a 4wd unit and will NOT fit under your zed properly. You are better of selling that (worth quite a bit to motorex) and picking up an RB25DET 5 speed. That gearbox should be fine to about 475- 500hp before you need to go to an O/S giken gear set.
A stand-alone computer system will work fine, providing your current instrament cluster runs off a factory stand a lone system. I would suggest a wire in system. Plug in is fine but unless you have someone with the complete wiring diagram in english of the skyline loom you will spend a fortune having it traced and such.
Go with an SX fuel pump for that part and get larger fuel lines feeding the fuel rail from the tank.
You will also need the front mount as the factory Zed I/C's are not even close to being effient enough for what you want.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
RazorGTR is offline   Reply With Quote
Old 07-15-2004, 11:07 PM   #6
SubaruImprezaYM
http://japimportsusa.com
I heard they actually put a skyline engine in a honda civic
it can do 1/4 in 10 AWD
try them
THIS IS JUST WHAT I HEARD
SubaruImprezaYM is offline   Reply With Quote
Old 07-16-2004, 02:01 AM   #7
tazdev
I'm still here
tazdev's Avatar
Re: Need some help ... about SKYLINE ENGINE ... !!!
I'm guessing he means the display in the R34 GTR
tazdev is offline   Reply With Quote
Old 07-16-2004, 04:54 AM   #8
GTES-t
GTES-t's Avatar
Here's an RB25DET in a 300zx:
It can be done, they love doing hybrid conversions in Japan. Here's the page with quite a few, including another alternative, the SR20DET in a 300zx.
http://www.meggala.com/hybridscss.htm
For actual conversion and costs, you'll have to contact a place that specializes in that.
Here's a couple of good places to contact.
300zx specialists:
http://www.jimwolftechnology.com/
Engine swap specialists:
http://mckinneymotorsports.com/
1990 Skyline GTE/S-t 4 Door Updated 6 Mar
Swapped out RB20E with RB20DET
Trans converted from Auto to 5-Speed...
Now with SR20DET 5-Speed
Installed Type M 5-lugs and brakes, R32 GTR rims and 2-Dr rear end (Tail lights & bumper)
1994 Isuzu AMU
US Spec Amigo with JDM Isuzu MU (Mysterious Utility, as it's called in Japan) nurf bars and hatchback style hardtop.
GTES-t is offline   Reply With Quote
Old 09-23-2004, 01:45 PM   #9
CrashGordon
you will need the wiring harness for the RB motor, an r33 rb25det transmission, rb26 ecu, the stock fan will not fit, you will most likely have to switch to a pusher fan setup. The mounts will be custom, as will the downpipes and exhaust. try calling mckinney motorsports to see if they have done this swap, or if they know what else is required.
"Diamonds, She'll pretty much have to"
CrashGordon is offline   Reply With Quote
Old 10-09-2004, 03:08 PM   #10
nismo_power
nismo_power's Avatar
The RB25DET driveshafts should mate with the 300zx TT yolk quite nicely. Another reason the 2-5 would do better. Besides, most drag GT-R's that I have seen run single turbo conversions anyways.
nismo_power is offline   Reply With Quote
Old 11-29-2004, 01:21 AM   #11
AkinaDriftKid15
Send a message via AIM to AkinaDriftKid15
one you go for it two i suggest you lay off the crack
AkinaDriftKid15 is offline   Reply With Quote
Old 11-29-2004, 04:22 AM   #12
my3rdskyline
my3rdskyline's Avatar
Send a message via AIM to my3rdskyline
Wtf? just let it be. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone. please just leave it alone. If it's been longer then like a month just please for the love of god let it be. just leave it alone.
my3rdskyline is offline   Reply With Quote
Old 04-20-2005, 12:59 PM   #13
DC1984
DC1984's Avatar
Send a message via AIM to DC1984
Wink
i dont know how well it will work in a 300 but in a 240, they use the rb25det RWD(rear wheel drive) transmission( 1200$ ) with the rb26dett motor, because the rb26 comes stock with an AWD(all wheel drive) transmission. even with that, your probably gonna have mounting problems, they make mounts for the 240 so with enough research and $$$$(a lot), im sure u can accomplish it.
DC1984 is offline   Reply With Quote
Old 05-11-2005, 07:47 PM   #14
huracan0613
huracan0613's Avatar
you don't know what you're getting yourself into. a friend of mine just did that and it's not the pretties thing in the world. yeah it will fit, it will work and it will do it's thing but, there's alot of things you'll need to make it work.
That's what I drive to work everyday, man.....I love it!
huracan0613 is offline   Reply With Quote
Old 09-05-2005, 10:31 AM   #15
boostmonkey2jz
i know this doesnt matter much but youl need an rb25 oil pan 2 the oil pan on the rb26 actually has the front differential in it and the rb25 and the rb26 are the same engine block so the trans and the oil pan will bolt right up
boostmonkey2jz is offline   Reply With Quote
I Need Some Help About Stage 4...please Help... fast_driving2007 SRT4 5 05-14-2007 03:02 PM
i need some help about a 350 idk if nyone of uns could help me but its worth a shot. S10 guy Engine and Transmission 2 04-26-2007 12:27 AM
need some advice about check engine light notenoughmoney Let's get Technical! 4 11-02-2005 04:26 AM
Hi Guys I need Some Help About AW11 MR2 WIN1029 Car Modeling 2 08-26-2003 02:50 PM
Need Some Help with an engine swap 1_revin_Silvia 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 3 07-06-2003 06:39 PM
