Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Talk
Old 04-09-2005, 08:52 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
speed sensor
i noticed when i was under my car that the speedo cable was bolted directly into the tranny and that there was no speed sensor there. i was wondering if theres suppost to be one on a 1987 5.0 5 spd, should i buy one and put it in? there looks like there is a 2 wire plug that would plug right in to a sensor. thanks for the help.
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 04-10-2005, 01:12 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: speed sensor
I believe 87 5.0 t-5's didn't come wit V.S.S.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 04-10-2005, 02:58 AM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
Re: speed sensor
GTStang.....that is rather odd. It might just be the different engines, but I had bought an 87 Mustang that had the V.S.S.....but then again it was an automatic and a 4cyl. Usually the VSS is located at the tailshaft on the speedometer cable itslef. Most new Ford vehicles have it. I mean it it not a real big deal if you have one on an older car, but I would look in a salvage yard or online to see if your car was suppose to have one
Old 04-10-2005, 11:15 AM
Re: speed sensor
ok thanks for the advise i'l look a little deeper to see if the cars suppost to have one b4 ordering one..
Old 04-10-2005, 03:45 PM
GTStang's Avatar
Stang Guy
Re: Re: speed sensor
Well I will claim total ignorance about 4cyl Mustangs... But I'm 98% sure that the speed density 5.0's don't have a V.S.S. When you go to do a Mass Air conversion it always tells you where to plug it in but there is no V.S.S.. You just buy the sensor and run the wires.
Old 04-11-2005, 01:01 AM
Re: speed sensor
Well the trans are quite different from mine and 5.0. I was looking at an 87 Crown Victoria today just to check something out and it has a VSS....it is a stupid little plastic thing that your speedometer cable slips into, plug the two prong wire into and that is where your gear goes on to the end of that
