Go Back   Automotive Forums .com Car Chat > Pontiac > Trans Sport
Old 01-13-2005, 02:31 AM   #1
GaryRay
1993 3.1L V6 Firing Order
Does someone have the firing order for a 1993 Pontiac Transport 3.1L V6?
Also whenever I punch down on the accelerator the engine bogs out especially on a hill, if I gradually accelerate it runs fine andy ideas?
GaryRay is offline   Reply With Quote
Old 01-13-2005, 07:07 AM   #2
LMP
LMP's Avatar
1-2-3-4-5-6
1,3,5 on the bulhead side of engine counted from belt
2,4,6 on the front side of engine ...................
I'dd check the TPS (throttle position sensor - a common problem) and the MAP (manifold air pressure) sensor...do you have any code? DO you know the procedure to get them from the CEL?
LMP is offline   Reply With Quote
Old 01-13-2005, 08:49 AM   #3
GaryRay
Re: 1993 3.1L V6 Firing Order
Originally Posted by LMP
1-2-3-4-5-6
No service engine light is on, so I haven't had any tests run. I am not sure how to get them from the CEL can you advise?
Old 01-13-2005, 09:58 AM   #4
LMP
LMP's Avatar
Jump together diagnostic plug connectors A and B with a small wire
www.avigex.ca/xport/plug.jpg
TUrn key ON
CEL light will blink 12 3 times (one ulse of light then 2 pulses, 3 times) then will start giving the codes, if any, like 23 will be 2 pulses, then 3 more..Once finished, it returns to code 12.
codes here:
www.avigex.ca/xport/codes31.jpg
