| Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums. |
'93 cutlass ciera, spark plugs
How do you change them, i just put on 100k and need new ones, i hope its easy.........
Re: '93 cutlass ciera, spark plugs
get yourself a sparkplug socket and a ratched head then pull them out put in new ones remember clean everything and id change the wires too
im not sure what size your engine is but if its a 4 cyl. it should be easy, but if its the v6 you will be in your garage for a while. by the way do you live in indiana?
#4 | ||
#5 | ||
Re: Re: '93 cutlass ciera, spark plugs
you will have to loosen the engine mounts on the top of the engine. THe engine will then rotate forward and you will have access to the rear plugs. On the top of the 3.1 there is a loop that you can place a prybar on. after the bolt is taken off of the mount let the engine come forward. you can then place the bolt on the other part of the engine and it will stay. Todd |
If your engine is a 3.3l then you dont need to loosen anything. only need a socket, and different size extensions. Might as well do the 02 sensor while your at it cuz that is back there also.
