Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 10-23-2003, 01:49 PM
TxRanger1996 TxRanger1996 is offline
Unhappy Overdrive Dash Light
I have a 1996 Ranger 2wd 4c auto trans 105K miles
Problem:
After driving 5-10minutes at 60-70 miles an hour the "OD OFF" light starts flashing. The transmission seems to be in a lower gear (other than in OD). I check the fluid level and it is fine (I checked the level with the engine hot and running and in park). I had the transmission serviced at the 55k mark.
Please help with a diagnosis........
Thanks
Old 03-06-2004, 08:54 PM
2000mudder's Avatar
2000mudder 2000mudder is offline
Re: Overdrive Dash Light
by now you prob had your trans rebuilt. mine did that and the valve body gasket blew and pluged up sensors and fried the trans. hope yours didnt cost $1800 like mine.
Old 07-31-2004, 12:00 PM
smashek smashek is offline
My truck is the same, did you ever solve this problem? The CEL Code is P0761 and the OD light flashes around 60-70 MPH. Any ideas on where to check for a wire short or other easy fix?
Old 07-31-2004, 12:11 PM
2000mudder's Avatar
there is no code p0761 for a 96.i have the codes from 96 to present and they stop at p0755.
Old 07-31-2004, 12:12 PM
2000mudder's Avatar
P0731
1103
Gear 1 Improper Ratio
P0732
1104
Gear 2 Improper Ratio
P0733
1105
Gear 3 Improper Ratio
P0734
1106
Gear 4 Improper Ratio
P0740
1204
Torque Converter Clutch Circuit Malfunction
P0744
1107
Torque Converter Clutch Solenoid Malfunction
P0745
1205
Pressure Control Solenoid Malfunction
P0750
1108
Shift Solenoid No. 1 Malfunction
P0755
1201
Shift Solenoid No. 2 Malfunction
Old 07-31-2004, 12:54 PM
P0761 Shift Solenoid
P0761 Shift Solenoid C Performance or Stuck Off is what the chart says and the code reader even noted it could be a bad circuit.
No Dash Lights in my '01 Grand Prix Heartless1 Grand Prix 2 11-17-2010 08:41 PM
Dash Lights & Battery Light LilBitEG Explorer | Explorer Sport Trac 2 09-10-2010 07:47 AM
Dash Lights Wont work. Staciewrath Alero 1 02-14-2010 10:22 PM
1998 Monte Dash Lights Will No Longer Work... ermiller79 Monte Carlo 0 12-08-2009 08:35 AM
99 Sunfire Dash Light & Radio Lights turn off when you turn on head lights fathershrubb Cavalier Problem Diagnosis 5 04-20-2009 05:26 PM
