Old 06-27-2007, 11:30 PM   #1
mic329
mic329's Avatar
WIP - Mclaren MP4/4
Hello all
I have started the 1/20 MP4/4 since mid of May and here are some pics on it.
Enjoy !!!
Mikusen
mic329 is offline   Reply With Quote
Old 06-27-2007, 11:34 PM   #2
mrawl
mrawl's Avatar
Re: WIP - Mclaren MP4/4
Beautiful clean work and photography. Now, cross your heart and hope to die, was there any photoshopping involved here? (j/k)
mrawl is offline   Reply With Quote
Old 06-27-2007, 11:38 PM   #3
klutz_100
klutz_100's Avatar
Old 06-28-2007, 12:56 AM   #4
mic329
mic329's Avatar
Thanks you for your comment.
Normally, I use Picasa to shapen those pictures.
Old 06-28-2007, 04:04 AM   #5
stevenoble
stevenoble's Avatar
Looks great so far.Which red did you use?
Steve Noble
stevenoble is offline   Reply With Quote
Old 06-28-2007, 04:25 AM   #6
gionc
Authorized Vendor
gionc's Avatar
Great job, picts are at a (great) modelling magazine's level.
gio
Old 06-28-2007, 04:46 AM   #7
mic329
mic329's Avatar
Thank you Steven. I have used MP4 red by Finisher's (a set of 3 bottles, including foundation white, MP4 red and florescent pink)
btw, I have seem in AF that you have made MP4/5B as well and I have a question on the fitting on the MP4/5B. Do you have any pictures on your MP4/5B showing that the cowl fitting with the monoque.
I have cut the front wing as well and I found that a big gap present in between. Thanks
Old 06-28-2007, 04:48 AM   #8
mic329
mic329's Avatar
Thank you very much.
Thank you Picasa as it helps improve the pictures as well.
Old 06-28-2007, 07:26 AM   #9
tehSAC
I Cant See The Photos
tehSAC is offline   Reply With Quote
Old 06-28-2007, 07:54 AM   #10
mic329
mic329's Avatar
Now should be okay
Old 06-28-2007, 05:27 PM   #11
stevenoble
stevenoble's Avatar
I used the same Finishers paints on my McLaren MP4/5B.They are very good paints.Regarding the pictures showing the cowl fitting onto the monocoque.I haven't any because the cowl did not fit onto the monocoque due to all the wires and stuff I added to the engine and side pods.The gap at the nose to main cowling join should be easy to take care of though.Fit a small piece of plastic card to the part where you sawed through the joint and file it to shape.This will replace the plastic you removed when you made the cut.
Steve Noble
Old 06-29-2007, 08:25 AM   #12
mic329
mic329's Avatar
Thanks Steven
I have checked the monocoque and I found that, unlike MP4/4 which the front nose is lying flat to the surface. For MP4/5B, the front nose is slightly higher and once it is glue to the base plate, the gap will going down and close up.
I have cut under the front nose a bit
and now the gap getting closer
I will use some styrene sheet which cut to strip and glue in between to form the flange on both sides.
Mikusen
Old 06-29-2007, 08:58 AM   #13
billypee
billypee's Avatar
Send a message via AIM to billypee
Great model. Great photos. It looks as though you are already 80% complete!
Kind regards,
Bill
On the workbench:
Completed WIPs:
Completed Models Gallery:
billypee is offline   Reply With Quote
Old 06-29-2007, 09:12 AM   #14
mic329
mic329's Avatar
Just start adding tiny details and now prepare for the exhaust pipes
Stay tune !!!
Old 06-29-2007, 06:15 PM   #15
Enzoenvy1
Enzoenvy1's Avatar
Beautiful...............................
Enzoenvy1 is offline   Reply With Quote
