Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Old 01-25-2002, 10:30 AM   #1
94civic
94civic's Avatar
SOHC Turbo Help
I planning on turboing my d16z6 motor but i want to know what i need to beef it up so that it doesn't blow up. Does my motor already come with low compression and if i do need to change my internals what site can i go to to order them. This is the turbo kit i'am planning on buying.
http://www.rollhard.com/apexturbointercooler.htm
94civic is offline   Reply With Quote
Old 01-25-2002, 12:15 PM   #2
sparq
AF Premium User
sparq's Avatar
Send a message via AIM to sparq
Re: SOHC Turbo Help
You can turbo a stock motor just fine...
Its when you want to go above like 8 psi of boost and stuff that you need to really look at what the hell you got going on in the motor. So if you are going for 6-8 psi of boost, dont worry about your internals ~ less they are shot anyways
AF's Official Asshole
RIP AUNIE
sparq is offline   Reply With Quote
Old 01-25-2002, 01:15 PM   #3
94civic
94civic's Avatar
i'm going to be runnig more than that, maybe like 12-16 psi. i know i have to change the pistons, rods, valves, valve springs, retainers and resleave the cylinders . anyone know where i can find these parts for cheap on the net
Old 01-25-2002, 07:14 PM   #4
piscorpio
Send a message via AIM to piscorpio
check out www.theoldone.com, they have endyn rods for pretty cheap, actually they have pistons and anything you could need for you D16 really.
piscorpio is offline   Reply With Quote
Old 01-26-2002, 01:21 AM   #5
madtownhonda
madtownhonda's Avatar
Send a message via AIM to madtownhonda
get some rods and pistons...9:1 or so..maybe half a point higher....you can run 10psi on a stock motor, just make sure your engine is still good and take it to a reputable tuner. if you want to go any higher than 10psi, I would start to look into building the bottom end.
madtownhonda is offline   Reply With Quote
FS: Sohc Turbo Kit + misc turbo parts, HMT!! QuikShifter Classifieds 2 10-18-2006 11:58 PM
Cam Sprocket on SOHC Turbo? Frostbyte Forced Induction 1 10-16-2002 01:59 PM
sohc turbo or ls motor/gsr tranny excivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 10 09-14-2002 08:39 AM
240sx DOHC SOHC turbo manifolds and intercoolers iboost 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 08-27-2002 08:12 PM
sohc turbo hondatool Forced Induction 10 06-14-2002 12:56 AM
