Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Talk
Old 06-10-2004, 09:39 PM   #1
Soupnutz
exhaust question
I was reading an exhaust article a couple of threads down and came up with a question. It was beeing said that shorty headers are not worth buying on a 4.6. So here's the question. I've got a 98 gt with a bassani cat back exhaust. I love the way it sounds and don't really want to change it. I was thinking about getting some headers but after reading that I will only get long tubes now. Is it just a matter of cutting the pipes and welding the cats on further back or what? What headaches come with putting LT headers on a pre existing aftermarket exhaust with the stock exhaust manifold?
Soupnutz is offline   Reply With Quote
Old 06-10-2004, 09:41 PM   #2
stang_racer20
stang_racer20's Avatar
Send a message via Yahoo to stang_racer20
I would just suggest getting a long tube x/h pipe to replace the stocker.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
stang_racer20 is offline   Reply With Quote
Old 06-11-2004, 12:24 AM   #3
GTStang
Stang Guy
GTStang's Avatar
Send a message via AIM to GTStang
Cons of LT headers are:
1. The install is usually more effort than shorties but I would argue this if you compare LT vs Equi-shorties on a 4.6.
2. LT headers cost more money.
3. You need to either modify or by a shortened H/X-pipe for to match the LT headers.
So if you buy say MAC LT headers with a matching MAC H-pipe for there LT headers. It will all bolt in and bolt right up to your Bassani cat-back no problem at all. No cutting or welding required.
I just used MAC as an example same would be true for BBK, Bassani whoever.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
GTStang is offline   Reply With Quote
Old 06-12-2004, 08:25 AM   #4
Soupnutz
Re: exhaust question
I just found something out, It had a bassani x-pipe also, everything rear of the exhaust manifold has been replaced. So doing it now would require modification of the x-pipe huh. could a muffler shop easily do that?
Old 06-12-2004, 11:35 PM   #5
351wStang
351wStang's Avatar
A saw or torch and a mig welder is all it would take.
351wStang is offline   Reply With Quote
Old 06-13-2004, 12:10 AM   #6
Soupnutz
Is upgrading to long tubes cost efficient compared to the horsepower gain over what I have now?
