Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 05-31-2005, 01:28 PM   #1
nock
my 95 neon engine?
I have a 95 neon and i want to put a better motor in it i was suggested do use a spoon engine but the freind was an idiot but then i posted a different thread under honda and on guy said to use a 4G36 or somthin and i was wonder in if a 2.2 dual cam would be better or not so if ne of u have a gess or somthin then e-mail me at [email protected] thanx
nock is offline   Reply With Quote
Old 05-31-2005, 04:24 PM   #2
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
A spoon engine in a neon, that is funny. I guess it could work, but you would have to shell out alot of money. The best engine swap for a neon, would be a 2.4 engine out of a stratus. It isn't a direct bolt-in, but with some minor mod's it can work. It has been done over and over again. If you need some more info, email or pm me.
das2123 is offline   Reply With Quote
Old 06-01-2005, 08:42 AM   #3
skatendestroy
Send a message via AIM to skatendestroy
Re: my 95 neon engine?
the best swap would actually be a srt 4 swap.....
skatendestroy is offline   Reply With Quote
Old 06-01-2005, 08:53 AM   #4
das2123
Re: Re: my 95 neon engine?
That swap is alot more complicated and alot more money. For the same amount and less time you can turbo a 2.4 stratus and have more power.
Old 06-01-2005, 09:05 AM   #5
skatendestroy
the swap is incredibly easy it is a direct bolt in the srt motors are the exact same external block as the 420a..
Old 06-01-2005, 10:36 AM   #6
das2123
The SRT-4 engine is not a direct bolt on to any first generation neon. The turbo is a direct bolt on to DOHC neons, but needs an adapter to fit onto SOHC neons. Where are you getting this info that the SRT-4 engine will bolt into a 1st gen?
Old 06-07-2005, 08:52 AM   #7
skatendestroy
http://www.automotiveforums.com/vbul...d.php?t=412710
If any thing tex is a relible source he knows his stuff.
Old 06-07-2005, 08:58 AM   #8
das2123
One big difference: That post was on a 2003, not a 95! The first and second generation wiring harnesses are completely different not to mention the engine bays are different as well.
Old 06-08-2005, 08:46 AM   #9
skatendestroy
Ahaha my bad theres somthing I overlooked..
Old 06-08-2005, 10:20 PM   #10
TEXSRT4
the srt motor will fit, but DAS is right, it will require a bit of tweaking. in the end it will be worth it though. while it is true, it will be cheaper to turbo a stratus motor, there is a lot more potential in an srt motor. 450hp on stock internals, the stratus wont be capable of that. if you want power, thats what you need to look into.
if you are going to do that, make sure you get the entire engine/tranny/wiring harness/computer from the SRT. that will make the install a lot easier
TEXSRT4 is offline   Reply With Quote
Old 06-09-2005, 08:48 AM   #11
das2123
But with that 450HP, comes broken motor mounts and broken axles. So put some money aside for some solid motor mounts and newer stronger axles
Old 06-09-2005, 10:27 PM   #12
TEXSRT4
not necessasrily. guys are running it, you just cant abuse it. motor mounts are $25 for a set, and axles arnt too bad. $500, and i know several 400+hp cars that are still running stockers even after many many drag runs
Old 06-10-2005, 09:04 AM   #13
das2123
On 1st gen neons? But true you can't abuse them.
