Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 02-27-2004, 03:51 PM
PhoenixX PhoenixX is offline
Send a message via ICQ to PhoenixX Send a message via MSN to PhoenixX
Lightbulb Turbo Charging a '91 Dodge Shadow using an '84 Daytona Turbo
I've come with the hopes of finding someone who knows about dodge shadows and/or daytonas.
I've got a 1991 Dodge Shadow With only 70,000 miles on it.
Sitting next to it in the garage, is an old, beat up 1984 Dodge
Daytona Turbo with 114,000 miles.
Rather than restore the Daytona(my first initial thoughts), I'd like to take the turbo, intercooler, and anything else I might need, out of it, and put it in the Shadow.
However I've realized autobody is completely different from automechanics, and I'm no guru on this topic.
I'd like to know if this can be done, how hard it is, and how costly?
Maybe even an In-depth tutorial on this, if there are any...
Any help would be GREATLY appreciated. Thx so much!
- Phoenix X
Old 02-27-2004, 09:28 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
You came to the right place.
I can help you, but first, what engine is in your Shadow and what engine is in your Daytona?
Old 02-28-2004, 12:46 AM
Post Engine Size
Thanks! My Dodge shadow is a 2.5L, the Daytona is a 2.2L Turbo.
If you need anymore info lemme know, im anxious to here your reply!
Old 03-01-2004, 10:23 PM
Polygon's Avatar
The Red Baron
Great, you're off to a great start. I have two words for you, engine swap. The problem with your engine is that the engine won't hold up to turbo charging very well. It just wasn't designed for it. It will cost you a lot more to turbo the 2.5L then it will to swap in the 2.2L from the Daytona. You said it had an intercooler so it was a Turbo II. You will want to swap everything from under the hood including the axles and transmission. It sounds daunting, but it is your best option. Also here is a best tech reference on the internet for the Turbo Dodges:
Gary Donovan's Dodge Garage.
This will tell you how to do anything you need to with a TD. Also, you might want to register at the Turbo Dodge Forums if you want to get into the TD community.
Old 03-01-2004, 11:15 PM
Post Axle and Transmission!?
Wow, that's horrific!
The problem is the Daytona has high mileage, and the shadow's engine, only half as much. The shadow also has a brand-new transmission.
I did find a 2.5L shadow Turbo Manifold http://www.ppuskas.com/bay/intakeb01.jpg
for sale. Is there anyway I can buy this manifold
and hook up the TII to it? since this is off a 2.5L shadow
won't it fit?
Obviously I'm new to this, but is there really no way around this?
I've been to Donovan's Garage earlier today, and learned a little
but he did mention turbo charging a non turbo P-Body car i believe.
I will join the TD forums also. Thanks for all your help!
Old 03-02-2004, 01:12 PM
ironman502 ironman502 is offline
Hey, Polygon, thanks for posting the link to turbododge.com. I've always wondered if there was a shelby dodge one around.
'85 BMW 325e
'87 Shelby Lancer #340
'00 Dodge Neon
Therefore, having been justified by faith, we have peace with God through our Lord Jesus Christ. (Rom. 5:1)
Old 03-02-2004, 03:28 PM
Polygon's Avatar
The Red Baron
Re: Axle and Transmission!?
won't it fit?
Yeah, I'm not even sure if that manifold will bolt to your block. I’m not very knowledgeable with the TBI engines. The problem is that the turbo engines from 1989 and up were different from the TBI engines. They were called the common block. No matter what you're going to have to swap out the engine if you want to go turbo. You can turbo-charge the engine you have, it will just be far too much money and time that the engine swap just makes more sense. Also, the Garrett T03 used in the TII won't bolt to that manifold. The 2.5L turbo cars were all TI and they used a Mitsubishi TE04H so you’d have to find a flange to bolt the Garrett from the Daytona on. You might not need to swap out the transmission depending on which one you have on the Shadow, but the axles will be a must.
I look forward to seeing you both at TD.com, there are a lot of people there and they are glad to help. It is a great community.
Old 03-02-2004, 04:23 PM
Re: Re: Axle and Transmission!?
There Is a user at TD that said he swapped a Turbo engine into his '91 Shadow, Carried over the Trans, but left the axles alone. He's driven over 1000 miles now and has had no problem. Why must the axles be swapped? Sorry for all the questions, you've been a great help!
Old 03-02-2004, 10:47 PM
Polygon's Avatar
The Red Baron
It was my understanding that all turbo cars got stronger axles than the non-turbo cars. I am sure you could get by with them, but the slightest wheel hop will probably tear them apart. I could be wrong though. If they are the same as the turbo cars then you don't have to worry, but it is my understanding that they aren't as stong.
Old 03-03-2004, 04:54 AM
Lightbulb A Matter of Opinion...
Thx so much for all your help Polygon, I've learned a lot from your posts, you've been a great help!
May I bother you for one more thing?
I'd like your opinion, givin the circumstances, and your knowledge.
Say you have the following cars:
'91 dodge shadow
75,000 miles
Interior: Excellent
Exterior: Fair
Transmission: New
EST. 100hp +/-
'84 dodge daytona turbo
114,000 miles
Interior: Very Poor
Exterior: Poor
Transmission: Original
EST. 150hp +/-
It's time for a change...
Would you swap engines,
Or restore the daytona?
or something else?
my lack of knowledge in this area
leads me to believe you'd make a
better decision in this, knowing you
are more experienced, and know
by making one of these decisions
you know what you are getting into.
I don't want to start something I
can't finish
Thx Again, for all your help!
Old 03-03-2004, 12:56 PM
Polygon's Avatar
The Red Baron
This all depends on which transmission you have in your car? Is it an automatic or a manual?
Old 03-03-2004, 01:03 PM
Post Transmissions...
Heh, I would love to have manual transmissions, but they both have automatics. If i remember right, the mechanic reffered to the Transmission in the shadow as the "305" tranny. when i go thte new tranny in the shadow, I wasnt around to "ok" the project, otherwise I would have had him put in a manual! It was pricey anyways....
Old 03-03-2004, 03:22 PM
Polygon's Avatar
The Red Baron
Well, this poses an interesting problem. I was under the impression that the Daytona was a Turbo II but since it has an automatic it has to be a Turbo I. They only made the Turbo II cars with manuals. If it does indeed have an intercooler than someone has started the Turbo II conversion. I was also hoping you would have the A-568 manual. This completely changes my opinion on what you should do. However, I have no idea what your mechanic meant by the "305" transmission. You car would have to have the A-413, which is the only automatic they used on the four cylinder cars. This isn't bad because you can run a lot of horsepower through the A-413, and you have the best version of it in your Shadow. In this case you wouldn't need to change the axles. This means that the Daytona also has the A-413, but it has the worst version of it and should be scrapped along with its axles. I no longer feel that you should swap engines either. I've done some research on your engine and feel that all you need to do is swap out the connecting rods and pistons and then do the Turbo II conversion. My previous fears were really only valid with earlier TBI engines.
Old 03-03-2004, 10:47 PM
Hey, if that Daytona is an '84, how can it be T II? I thought the turbo 2 engine first came about in '87. Could it be that the car was originally a T I auto that somebody converted (assuming it's really a T2 now)?
'85 BMW 325e
'00 Dodge Neon
Old 03-03-2004, 11:21 PM
Polygon's Avatar
The Red Baron
Re: Turbo Charging a '91 Dodge Shadow using an '84 Daytona Turbo
Yeah, it did, which completely escaped my mind. However, since he is saying that there is an intercooler, it sounds like someone did try to convert it to a Turbo II.
2.5L Turbo Dodge Shadow Problem, Need Help! Rub-A-Dub General Discussion 2 04-01-2005 10:07 AM
'91 Dodge Daytona ES opitica Car Buying Q&A 1 01-24-2005 01:21 PM
Fuel Pressure For 1989 2.5 Turbo Dodge Shadow Rub-A-Dub Other Cars 1 11-04-2004 04:51 PM
Fuel Pressure For 1989 2.5 Turbo Dodge Shadow Rub-A-Dub General Discussion 0 09-18-2004 06:15 PM
1992 dodge shadow turbo install WHITE LIGHTING General Discussion 1 12-02-2003 01:21 PM
