Go Back   Automotive Forums .com Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-28-2004, 12:51 AM   #1
integra111
Send a message via AIM to integra111
Question Thinking of doing a h22 swap
I was thinking of swapping my h23 for a h22a. Just wondering how easy it is of a swap. Im guessing i can use the same motor mounts but obviosly the wiring gonna be different considering its a engine from a prelude in japan. If anyones done this swap can you tell me how you did it and how the car turned out. I have no experience with engine swaps but i would like to try one.
thanks for any input..
integra111 is offline   Reply With Quote
Old 03-29-2004, 03:12 AM   #2
SenseiAccord
Re: Thinking of doing a h22 swap
i thought USDM and JDM engines were the same other than different HP/Torque output.
SenseiAccord is offline   Reply With Quote
Old 04-01-2004, 11:46 PM   #3
integra111
no they gotta be a little different set up. I know all the wires dont match, but not sure what else. Anyone with a jdm engine swapped out there?
Old 04-02-2004, 12:33 AM   #4
DeleriousZ
DeleriousZ's Avatar
Send a message via MSN to DeleriousZ
Don't do it.. it's NOT WORTH IT, the amount of hp gained is no good when cornering, because the added weight of the engine (a few hundred lbs) will throw the balance of your car WAY OFF. if you're looking for a good n/a engine, go for the jdm b18c, or the type R b18c. less hp, but the swap will take way less time and cause a LOT less headaches... i know a guy that swapped an h22a into his integra.. the swap took him 3 months and ended up costing him near triple his first estimate. the ONLY situation i would even try swapping an H series engine into an integra is if you were drag racing ONLY.
it's not worth it.
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
DeleriousZ is offline   Reply With Quote
Old 04-02-2004, 12:42 AM   #5
CivicSpoon
There is no Spoon
CivicSpoon's Avatar
All you'll have to do is use the ECU of the H22 and wire up vtec; since you already have an h23 in there. You'll be able to use the same shift linkage, mounts, axles, etc. Other than the hastle of wiring the rest should be pretty straight forward.
What car is this being swapped into? What mounts do you have in there? My buddy swapped one into his 95 Civic 4dr it turned out pretty good. He ran into some suspension and axle problems but you already have an H-series motor in there so it shouldn't be a problem for you. Here's some picks of his car: http://members.cardomain.com/hybridcivich22a
CivicSpoon is offline   Reply With Quote
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 12:43 PM
gsr swap vs. h22 swap PortoRock95 Integra 17 05-01-2003 11:53 PM
Is anybody doing a H22 swap?? I need the old motor! ShockJon Accord/TSX/Accord Hybrid 4 09-02-2002 07:38 PM
Is any body doing a H22 swap I need the old motor!!! ShockJon Engineering/Technical 1 08-10-2002 11:20 AM
do you think I could swap... Darkwing '71-'87 Civic | CRX 9 12-06-2001 01:55 PM
