Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 06-02-2004, 12:57 PM   #1
whitebeast
Send a message via MSN to whitebeast
buying a zr2
i am wanting to buy a 1998 or newer s-10 ZR2, i was woundering what are the biggest problems that occur with them and what should i like for when looking at the used ones.
whitebeast is offline   Reply With Quote
Old 06-02-2004, 06:51 PM   #2
movin2stereo
movin2stereo's Avatar
Re: buying a zr2
Where would you like to start?I bought a 98 ZR2 with 100,000 on it.At the time I got a good deal.Then it started...................hell................From the top,waterpump(within the first week),intake gasket(check for this on the 4.3),ball joints(all),front wheel bearings,rear calipers&brakes,engine(not even 3 payments into it),steering stabilizer,exhaust,door pins&bushings(driver side),tailgate cables,front brakes,and a water leak in the cab(which I found).That names a FEW problems I had.That's a good start to look for in a S-10.
movin2stereo is offline   Reply With Quote
Old 06-02-2004, 10:10 PM   #3
wehswarriorS-10
Send a message via ICQ to wehswarriorS-10
Re: buying a zr2
looks like u just got a severly ragged out zr2, cuz all of the ones i have ever seen that havent been like totally abused, and even the few that i know of that have seen alot of time in the woods are still good trucks, they run good, they go good, they look good, and generally dont ahve any major issues
wehswarriorS-10 is offline   Reply With Quote
Old 06-03-2004, 05:16 AM   #4
movin2stereo
Re: buying a zr2
That's just it,the truck looks good.When buying something used you just don't know what your getting into.
Old 07-25-2004, 09:02 AM   #5
ZeekyZR2
I bought a used 2000 Zr2 and it is great. The only problem i've got is that the fuel pump keeps going and the door pins are bad.
ZeekyZR2 is offline   Reply With Quote
Old 07-30-2005, 06:26 PM   #6
brightdim03
Re: buying a zr2
always take a new vehicle to an ASE cert mech for a total inspection before you buy it, i wouldnt buy a Zr2 if it was older than 2001 they worked most of the kinks out by then, dont be surprised if it runs hotter than most engines around 210, the 4.3 its duable and is hard to kill, but i wouldnt buy it if it runs hotter than 225 and make sure you have the transmition fluid valve examined they are known for problems later in life
brightdim03 is offline   Reply With Quote
