Old 03-03-2004, 01:26 AM
Carson_101 Carson_101 is offline
Knock sensors
I have a code 43 on my check engine light on my '93 Chevy truck that has a 5.7 and according to a local automotive parts house I should check the knock sensor and associated wiring for loose connections and such. Where is the knock sensor and how would I check it?
Old 03-03-2004, 12:15 PM
12gauge 12gauge is offline
KNOCK SENSOR
WE HAVE A VERY SIMILAR TRUCK.
YOUR KNOCK SENSOR SHOULD BE DIRECTLY IN FRONT OF THE STARTER, IT THREADS INTO THE SIDE OF THE BLOCK.
THE ONLY METHOD THAT I AM AWARE OF TO TEST IT IS:
-HOOK UP A TIMING LIGHT
-ENSURE YOUR TIMING IS CORRECT
-WHILE WATCHING THE TIMING, TAP ON THE BLOCK WITH SOMETHING METAL (TIMING SHOULD RETARD)
-IF NOT TAP HARDER
-IF IT STILL DOESNT RETARD, YOUR SENSOR IS PROBABLY BUNK
GOOD LUCK
-12 ga
Replacing Evap. canister Control Valve, Boost Sensor, and Knock Sensor? raja Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 16 06-04-2007 04:25 AM
Crazy knock in 3rd, o2 sensor or knock sensor bad? nates6969 Eclipse Problem Diagnosis 16 06-23-2006 10:11 AM
Knock Sensor and ECT Sensor snizzugglesmaxima Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 10-05-2004 07:53 PM
2000 Yukon How to Replace Fuel Sensor & Knock Sensor mrchiqui Yukon 0 06-24-2004 06:55 PM
Knock sensor and O2 sensor jmmax Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 02-24-2004 12:51 PM
