Old 01-20-2004, 12:14 PM
Jared_80 Jared_80 is offline
Banned
Could Direct prot fuel injection cure knocking?
I have been doing reserch on direct prot fuel injection and I was thinking that it would be almost imposable for a properly timed system to knock. I am making reference to the DPFI systems that inject right onto the sparkplug near the top of the compression stroke. It seemes to me like the rate of injection could control the rate of the burn no matter what the cylinder pressure or temparature.
Old 01-20-2004, 03:17 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Re: Could Direct prot fuel injection cure knocking?
um, aren't "port" fuel injection and "direct" fuel injection necessarily different?
* port injection - fuel is injected into the intake port
* direct injection - fuel is injected directly into the cylinder
Yes, it seems right to me that you cannot have anything but a relatively slow burn if you don't have a premixed charge. The reaction will be diffusion (or mixing) limited, so there isn't a possibility of simultaneous combustion of all the fuel.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 01-22-2004, 12:40 PM
Banned
I don't know why they named it that, but that is the name that they gave it. What would be the downside of using a system like this??
Old 01-27-2004, 12:24 PM
Banned
Any body else have any idea?
Old 01-27-2004, 12:36 PM
bigol jonson bigol jonson is offline
Banned
fuel injection will NOT cure pinging there are reasons
a motor pings and as long as your compression and timing are correct among other things your motor should not ping i would also look at the egr but as for you hideously ridiculous question if you want an answer here it is plain and simple please for the love of god dont work on your own car as a mechanic i hate working on things the owner screwed up
Old 01-29-2004, 01:03 PM
Banned
Re: Re: Could Direct prot fuel injection cure knocking?
For your information I am a certified mechanic, It was not a stupid question you were just too slow to understand it. You should not come to the tech forum, you are just going to get confused here, go home.
Old 01-29-2004, 01:57 PM
Expense, limits of in-cylinder mixing (needs more swirl for one), requires higher injection pressure, allows less time for flame propagation and slower flame propagation. There are OEMs working on it, and there are some production vehicles that use it.
Old 01-29-2004, 03:56 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
mitsubishi has developed a direct injection engine, you can read all about it on this site . anyhow if i remember correctly it is computor controlled in such a way that when the vehicle is under load it injects during the compression stroke for better torque and when performance is needed it is injected during the intake stroke for better mixture, another feature they developed with this engine is a near viritical intake port to help the air and fuel swirl ds as it enters the cilinder.
read for yourself tho, its been a while for me
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 01-29-2004, 04:45 PM
454Casull 454Casull is offline
Orbital has designed a system that doesn't require swirl in order to have an atomized charge. Very effective, IMO.
http://www.orbeng.com.au/orbital/orb...owpressure.htm
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 02-03-2004, 12:07 PM
Banned
Those are all things that can be worked around, do you know somthing that would be detromential to it?? What production cars use this kind of injection???
Old 02-03-2004, 12:23 PM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
its say on #3 it injects air to improve combustion and emmissoins of NOx. wouldn't injecting air make the mixture lean there for increasing combustion temperature and make more NOx?
But since this involves EGR that might compensate for the temperature.
Anyways Direct Injection is the way to go.
I disregard my perceived image in the persuit of knowledge.
Old 02-03-2004, 02:00 PM
Re: Re: Re: Could Direct prot fuel injection cure knocking?
A leaner mixture won't necessarily result in increased combustion temps (in this case it probably doesn't).
Old 02-03-2004, 03:40 PM
cvcc_wagon's Avatar
it seems as though it may be the way to go in the future, mitsubishi clames something like 10% more power than an engine with the same volume, and it opens more doors as far at tunablility goes as well. just my tho
Old 02-03-2004, 06:29 PM
It doesn't say that it leans out the mixture. Where does it say that?
Old 02-04-2004, 04:21 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Re: Re: Re: Could Direct prot fuel injection cure knocking?
The GDI Mitsi's are very common in Japan, and many models are now only avliable with GDI spec engines. They are becoming more common in new cars sales here in NZ, and in Europe, but the high cost of the engines in export markets still means they are not as common as they could be.
However, all the GDI vechiles Iv seen as used imports here in NZ have all been economy and familiy orintated, the closest thing to a performance model Iv seen is the short wheel base V6 Pajero.
However while not exactly quick, they are VERY efficant, my mother used to have a 1.8 Gallant which was quite thirsty for a small car, however two good mates have both recently got later model GDI 1.8l gallants, which use the same engine, but with a GDI head etc. They areproving to be very very economical even if they aren't that fast.
That Mitsi site is actualy very good, and goes into a surprising amount of detail (altough not a lot of detail for the engineers).
I recomend having a look starting at this page: http://www.mitsubishi-motors.co.jp/i...GDI/page5.html
Ferrari to use direct fuel injection jeffolsoned General Discussion 2 08-12-2014 06:31 PM
Classic mustang to 5.0 fuel injection novi Performance 7 09-05-2009 04:05 AM
Direct port nos injection boostjunkie333 Engine, Transmission and Drivetrain 10 08-25-2009 12:27 PM
Could high Octane fuel like 101 cure no NOx problems ? Jason A Engineering/ Technical 0 02-04-2004 08:09 PM
