Old 02-11-2012, 11:23 AM
zigzag88 zigzag88 is offline
Cool 94 chev pu 5.7 liter code 33
tested map sensor working ok found 5 volt referance on referance wire,ground on ground wire ,and 4.3 volts on map return wire, light green wire , with map sensor disconnected still has 4.3 volts comming from pcm side traced wire to ecm . no shorts to power the map signal wire . i even cut wire close to pcm and still has 4.3 volys on pcm side of wire , tests said bad pcm installed another one and same problem any help could it be a bad pcm with the same problem ,map signal wire shouldnt have power from it with map disconnected?
Old 02-12-2012, 05:51 PM
jamesslcx jamesslcx is offline
Re: 94 chev pu 5.7 liter code 33
Zigzag, I looked up code 33 in my Haynes Emission book it says map sensor or circuit low vacuum, Maf sensor or circuit voltage out of range (probably high).
5.7 vortec towing chaurik Suburban 4 12-07-2011 09:43 AM
5.7 Vortec SCPI to MFI Manifold Swap 1998_Silverado_WI Silverado 6 08-30-2011 09:25 PM
please help 5.7 liter hawk713 Caprice 1 04-22-2010 09:05 PM
1996 gmc 5.7 won't start-no spark 600cuin Sierra 5 11-13-2009 01:03 PM
a CHALLENGE!! ('93 5.7 Intermittent no-spark) cmjj42 Roadmaster 3 05-06-2009 12:55 PM
