| Engine intakes, exhaust, turbos, nitrous. |
primera exhaust manifold
Will the exhaust manifold bolt right up to the stock exhaust system of a 96 g20? And if I have to have a new pipe made are there any crazy flanges that I will have to locate? Also, what about the O2 sensor? Thanks
Lucas Barr 1996 infiniti G20t 1997 nissan 200sx se Last edited by barrlucas; 06-12-2001 at 10:58 AM. |
I asked this question both here and on se-r.net. Both with no responses. So I did a little research on my own (what I should have done from the start) and thought I would post what I found for future reference. The primera tubular exhaust manifold is made of stainless steel and flows better than the us spec cast manifold, but not as well as a hotshot or stillen header. To make this work you would have to figure out a way to incorperate the O2 sensor into the manifold. I have talked with a few people who said the best way to do that would be to have someone experienced in welding stainless steel to build up a spot to drill and tap for the sensor. The next problem is the pipe that goes from the exhaust manifold to the rest of the exhaust. The best sounding solution to me is to cut the flange off of the stock pipe, cut a few inches out of the pipe and weld the flange back on. After finding all of this out I have decided not to use the primera manifold on my car because by the time I buy the manifold, pay someone to weld for the O2 sensor, cut and weld the downpipe, and then put it all on, it will probably cost 200 dollars anyway, save another 150 and you have a hotshot header with a lot less hassels. Just my 2 cents.
Lucas Barr 1996 infiniti G20t 1997 nissan 200sx se |
Banned
Thanks Lucas. I saw your plea for help on the se-r list too. I've learned from experience that if no one responds then no one knows. It's a little annoying but you have to live with it. Glad to see instead of getting frustrated and flinging insults around, like I've seen some people do, you went and researched it yourself.
Nicely done! |
Yeah, thanks man. I was running up againsta same problem with my car. Doing a motor transplant ... good research there....
