How do you make the signal lights blink faster?
need some info on how to make blinkers faster...thanks
Off playing with fire.
![]() Join Date: Mar 2001
Welcome to AF
Here is what you need to do. I dont know if the pics will look the same on a Accord, but they will be similar. You need to remove the flasher relay. It should be similar to this: Open up the flasher and look for this resistor: You will need to change this resistor to make your signal blink faster, or slower. The resistance is around 90K If you want to make your signal blink twice as fast as stock, then you would replace the resistor with a 45K. The lower the resistance, the faster it will blink. |
OR you could buy a replacment flasher relay off of ebay for $10-$30
But they have them for different years. If your car is from 98-02 go here: http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1660539011 If you car is from 94-97 go here: http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1660539064 The auctions end in 3 days & 6 hours from now....8 pm on Wend. Nov. 7th |
I have an adjustable one at home that's never been used if you want it for $15
[email protected] It's real easy to install, you take out the existing flasher unit and replace it with this one. It has a knob attached so you can adjust the rate it flashes. |
or you can put the bulbs in the other way around but you will have to make notch inside the holder so it will go in.
Re: How do you make the signal lights blink faster?
you can put in a leb bulb that will work too
#7 | |
led
