Go Back   Automotive Forums Car Chat > Subaru > General Discussion
Old 01-11-2004, 05:16 PM
Michael S. Michael S. is offline
Unhappy '87 GL EA-82 SOHC 1.8L Oil Pump Removal
I have an '87 GL Wagon with a 1.8L SOHC EA-82 engine. I would like to rebuild the oil pump, and have all the necessary seals, etc. I attempted to remove the oil pump, but so far was not successful. As far as I can tell there are four bolts that attach the pump to the engine, and I removed them, but the pump won't budge. I'm afraid to force and pry any further, whereby I might break the aluminum housing. Has anyone had experience in removing an oil pump in this model? In addition, does the timing belt ride on a sprocket attached to the oil pump?
I would appreciate any guidance from someone who has experience in this matter. Thanks!
Old 01-17-2004, 03:52 PM
ellets ellets is offline
oil pump
Yes pass side belt does drive pump. I think there 5 bolts holding pump. seems like one is hard to see. Also watch o-ring seal on pump. If it doesn't seal properly the darn thing will suck air and cause valve lifters to click bad. Found this out the hard way.
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
